IBASSO AMP8 MK2 Discrete Amplifier Module for DX240 Black
iBasso unveils with the AMP8 MK2 a discrete amplifier module that can be installed on the iBasso DX240 Digital Audio Player (DAP). Its architecture uses discrete components rather than AOPs, in order to provide high output voltage and current, while maintaining a low output impedance and offering excellent measurements
By buying this product you get 20 loyalty points
Reference : 15971
209,00 €tax incl.
174,17 € tax excl.
iBasso AMP8 MK2
iBasso AMP8 MK2 Module Amplificateur Discret pour DX240
The AMP8 MK2 has a voltage variation of ±8V, improving the dynamics and the headroom for a particularly precise and musical reproduction. Bipolar transistors are used and matched to ensure excellent linearity. The transistors used in the buffer stage have an output current of 2000mA, allowing the amplifier to accompany both sensitive headphones and high impedance headphones. We also find high quality ERO capacitors participating in the high quality of sound restitution of the AMP8 MK2.
Finally, the AMP8 MK2 offers a double output. Indeed, it has a balanced output on 4.4mm jack and an unbalanced output on 3.5mm jack, allowing it to adapt to all listening devices.
Product typeAmplifier module
Outputs1x Balanced Jack 4.4mm
1x Single-ended Jack 3.5mm
Average play time9.5h
Balanced Jack 4.4mm output measurements
Max output level6.2Vrms
Output power980mW @ 32Ω
128mW @ 300Ω
Frequency response10Hz - 45kHz (±0.3dB)
SNR125dB
Dynamic range125dB
THD+N-114dB @ no load
-113dB @ 300Ω
-101dB @ 32Ω
Crosstalk-122dB
Output impedance0.55Ω
Single-ended Jack 3.5mm output measurements
Max output level3.1Vrms
Output power281mW @ 32Ω
32mW @ 300Ω
SNR122dB
Dynamic range122dB
THD+N-110dB @ no load
-109dB @ 300Ω
-98dB @ 32Ω
Crosstalk-117dB
Output impedance0.32Ω
iBasso unveils with the AMP8 MK2 a discrete amplifier module that can be installed on the iBasso DX240 Digital Audio Player (DAP). Its architecture...
