This extension is for the XD-05 in XDUOO. Its function is to add wireless connectivity to DAC / headphone amplifier.
The device takes advantage of the Bluetooth standard 5.0 24MB / s with apt-X medium through Qualcomm CSR8970 chip.
This allows playback and lossless compression able to dynamically adapt to the constraints inherent in différnets audio formats.
Result, the transfer rate and are optimized audio quality to find the best compromise and properly encoded audio files offiront rendering very near CD quality, even wirelessly transfer.
These performances allow the BL05 to make reading without delay and without charge related interruptions between two tracks. Songs can thus be linked together without latency for a complete audio immersion.
With 10 meters brought this extension provides enough coverage to enjoy complete freedom of movement, even in a very large living room.
On one device to another, the connectors are directly integrated into the PCB and held firmly. This sigifie that all is not based on welded and fragile son, but on firmly installed components and the mechanical constraints will be largely absorbed by enclosures. This construction thus permits a high resistance over time.
This reception module is supplied with a protection used to lock the volume knob XD-05. This will prevent accidental disturbances potentially dangerous if the amplifier is not located in an accessible location directly during playback.
The module has its own charging port and the device can be loaded even when the system is installed.
The use bluetooth allows a range up to 15 hours of playback.
| Specifications | |
| Type | Bluetooth receiver extension |
| bluetooth standard | 5.0 AAC SBC APTX |
| THD | 0.01% |
| Sensitivity | 0.5Vp-p |
| Food | 5V/05.5A |
| Scope | 10m |
| Dimensions | 72x22.8x14.8mm (29.3 with connectors); |
| Parts supplied | |
| USB charging cable | x1 |
| Manual | x1 |
| warranty card | x1 |
| Protection volume XD-05 | x1 |
| Input | Bluetooth |
| Output | Jack 3.5mm |
| DAC / ADC Chip | NC |
| Max sampling rate | NC |
| Color | Black |
| Transmission / Reception protocol | Bluetooth |
