ELTAX MONITOR III NEO Active Bookshelf Speakers Bluetooth White
The Eltax Monitor III Neo is a 2-way active bass-reflex bookshelf speaker designed to deliver complete stereo reproduction within a compact system. It relies on an architecture combining 2 × 50 W Class D integrated amplification and an extended frequency response from 55 to 22000 Hz, ensuring balanced reproduction with consistent driver management across the full spectrum.
By buying this product you get 34 loyalty points
Reference : 22071
349,00 €tax incl.
290,83 € tax excl.
Eltax Monitor III Neo Active Bookshelf Speakers 2x50W Bluetooth 5.3 White (Pair)
Eltax Monitor III Neo : Front view
The Eltax Monitor III Neo is a 2-way active bass-reflex bookshelf speaker designed to deliver complete stereo reproduction within a compact system. It relies on an architecture combining 2 × 50W Class D integrated amplification and an extended frequency response from 55 to 22000Hz, ensuring balanced reproduction with consistent driver management across the full spectrum.
Suited to both domestic Hi-Fi configurations and audiovisual use, it combines wireless, digital and analogue connectivity, allowing multiple sources to be centralised without multiplying interfaces. This approach enables it to function as a standalone system, while maintaining operational stability and sonic clarity suited to everyday use.
Eltax Monitor III Neo : 2-Way Architecture
The 2-way architecture pairs a 25mm dome tweeter with a 130mm treated cellulose pulp mid-woofer, covering a frequency response from 55 to 22000Hz with a controlled crossover point at 3100 Hz. The 12 dB per octave filter slope structures the energy distribution between drivers while limiting audible phase interactions.
The bass-reflex loading extends low-frequency reach, while the polypropylene dust cap on the mid-woofer stabilises cone behaviour, reducing turbulence and improving clarity in the lower spectrum. This combination delivers balanced reproduction, where bass extension articulates naturally with the precision of the midrange and treble registers.
Eltax Monitor III Neo : On a desk
Eltax Monitor III Neo : On a TV unit
Eltax Monitor III Neo : 2x50W Amplification
The 2×50W Class D integrated amplification relies on high efficiency, limiting thermal losses while enabling the use of a compact power supply — favouring bookshelf-format integration without compromising power availability. This architecture delivers stable dynamic response, capable of reproducing level transients without perceptible compression.
A signal-to-noise ratio exceeding 90dB maintains a low noise floor, preserving the clarity of fine detail even at low listening levels, while this controlled power management contributes to consistent operation over extended sessions. This approach thus delivers usable, stable dynamics suited to prolonged use in a residential environment.
Eltax Monitor III Neo : Extended Audio Connectivity
The combination of digital and analogue connectivity allows the speaker to accommodate a variety of sources without unnecessary conversion. Bluetooth 5.3 ensures stable wireless transmission with reduced latency, while the USB-C interface establishes a direct digital connection to a computer source, limiting conversion stages that could degrade the signal.
This approach extends further with the integration of an HDMI ARC input, simplifying audio retrieval from a television while enabling synchronised control, while the RCA line and MM phono inputs allow connection of traditional Hi-Fi sources and turntables respectively without external preamplification. The optical input isolates the signal from electrical interference, preserving its integrity, while the filtered subwoofer output — covering 20 to 120Hz — enables low-frequency extension via a dedicated subwoofer. This connectivity versatility allows all use cases to be centralised within a compact, straightforward system.
Eltax Monitor III Neo : Next to a turntable
Technical specifications
Product typeActive speakers
Speaker typeBass Reflex
Number of channels2
DriversTweeter Ø25mm
Mid-woofer Ø130mm
Sensitivity88dB
Amplification typeClass D
Power output2x50W
Frequency response55Hz-22kHz
Nominal impedance6-8Ω
Inputs1x USB-C
1x RCA
1x MM Phono
1x Optical Toslink
1x HDMI-ARC
Bluetooth 5.3
Output1x Subwoofer output (RCA)
Power supply100-240V AC 50/60Hz
Dimensions195 x 325 x 229mm
WeightActive: 5 kg
Passive: 4.4 kg
ColourWhite
Package contentsSold as a pair
1x Remote control
1x AC power cord
InputHDMI ARC
InputPhono
ColorWhite
Lowest frequency (Hz)55
Highest frequency (Hz)22000
Power (W)50.0
Number of ways2
Number of loudspeakers2
Speaker typeActive
Speaker form factorBookshelf speaker
ELTAX MONITOR III NEO Active Bookshelf Speakers 2x50W Bluetooth 5.3 White (Pair)
The Eltax Monitor III Neo is a 2-way active bass-reflex bookshelf speaker designed to deliver complete stereo reproduction within a compact system....
