By buying this product you get 319 loyalty points
The Tonewinner SW-D9000 active subwoofer is a bass reflex subwoofer equipped with a 45.72cm driver for an RMS power of 1500W under 3Ω, and can reach 8000W at peak. It offers numerous options such as crossover frequency adjustment, 7-band equalisation, volume control and 0°-180° phase inversion. Six vents on the front panel improve bass response. In terms of inputs, you can choose between an RCA line input or two other inputs: single-ended RCA LFE and balanced XLR. Furthermore, the SW-D9000 also offers an LFE output.
In order to deliver powerful bass, the SW-D9000 has been equipped with an impressive 45.72cm diameter driver coupled with a 115mm voice coil and a dual magnet circuit. This configuration allows you to get the most out of the 1500W Class D amplification, ensuring powerful and dynamic bass reproduction, capable of reaching frequencies as low as 11Hz.
Thanks to the Tonewinner app available on Android and iOS, the SW-D9000 offers 7-band equalisation settings, crossover frequency adjustment and phase inversion, allowing you to perfectly tailor your subwoofer's performance to your listening environment and usage.
1 | Power supply voltage switch |
2 | Power switch |
3 | Power socket |
4 | Fuse |
5 | Sub XLR input |
6 | Sub RCA input |
7 | Sub output |
8 | RCA line input |
9 | Volume control |
10 | Mute function / Confirm button |
11 | Menu button |
12 | LCD Screen |
Product type | Active subwoofer |
Driver diameter | Ø45.72cm |
Amplification type | Class D |
Power output | RMS : 1500W Max : 8000W |
Frequency response | 11Hz - 200Hz |
Phase setting | 0 - 180° |
Impedance | 3Ω |
DSP / EQ | |
Inputs | 1x LFE XLR 1x LFE RCA 1x RCA stereo line in |
Output | 1x LFE RCA |
Dimensions | 630 x 695 x 832mm |
Weight | 87kg |
Color | Black |
Package | Vendu à l'unité |
