WIIM SOUND DISPLAY Connected Speaker with Screen White (Unit)
The WiiM Sound Display is a connected speaker with a screen. It is a two-way speaker with a 100W amplification system powering its three speakers. It also incorporates a range of wireless connection technologies such as WiFi 6E and DLNA, Chromecast, Spotify Connect, and Bluetooth 5.3 protocols supporting the LC3 high-definition codec.
By buying this product you get 34 loyalty points
Reference : 21174
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 17-11-2026.
WiiM Sound Display Connected Speaker with Screen White (Unit)
Photo of WIIM SOUND DISPLAY speakers
The WiiM Sound Display is a connected speaker with a screen. It is a two-way speaker with a 100W amplification system powering its three speakers. It also incorporates a range of wireless connection technologies such as WiFi 6E and DLNA, Chromecast, Spotify Connect, and Bluetooth 5.3 protocols supporting the LC3 high-definition codec. WiiM has ensured that wireless connectivity remains high-definition with support for sampling rates up to PCM 24-bit 192kHz. In addition, it offers numerous features including a 10-band acoustic equalizer, automatic room correction, and the ability to pair multiple speakers and a sub pro for multiroom or home theater use. Versatile, the WiiM Sound Display is also compatible with Alexa, Siri, and Google Assistant voice assistants for simplified control.
WiiM Sound Display: Audio quality at its best
The WiiM Sound Display speaker's 100W amplification system, coupled with its two tweeters and 10cm woofer, provides sound for a large space. It also supports high-resolution streams up to PCM 24bit 192kHz, allowing users to enjoy high-resolution streaming.
The quality of the WIIM SOUND DISPLAY
WiiM Sound Display: Extended connectivity
The WiiM Sound Display speaker has extended connectivity to suit a variety of configurations: WiFi 6E, Bluetooth 5.3, Ethernet, mini-jack, Chromecast, Spotify Connect, TIDAL Connect, etc. The speaker is also compatible with Alexa, Siri, and Google Assistant voice assistants for simplified control.
WIIM SOUND DISPLAY connectivity
WiiM Sound Display : Bluetooth LC3
Bluetooth 5.3 functionality compatible with the LC3 codec offers audio quality up to 32-bit 96 kHz via wireless connection. Convenient for quick connection using a source device such as a smartphone or tablet.
The Bluetooth functionality of the WIIM SOUND DISPLAY
Multiroom and home theater functionality of the WIIM SOUND DISPLAY
WiiM Sound Display: Multiroom and home theater
The WiiM Sound Display speaker can be easily integrated into a Dolby 5.1 WiiM system as a main or satellite speaker. It is also possible to pair two speakers and add a WiiM Sub Pro for an immersive experience.
WiiM Sound Display: Advanced acoustic customization
A 10-band graphic equalizer, a parametric EQ with 24 preset profiles, and an automatic room correction function allow you to tailor the sound to your taste and the speaker environment using the WiiM Home app.
Audio rendering customization
WiiM Sound Display: Screen and touch interface
On the front of the speaker is a circular screen, while on top is a circular touch interface with a diameter of 4.5 cm that provides access to the speaker's basic controls.
Overview of the WiiM Sound Display speaker
Overview of the WiiM SOUND DISPLAY speaker
1Screen
2Speakers
3Volume +
4Previous track
5Volume -
6Next track
7Pause / Play
Product typeSmart speaker
Power100W
Speakers2x Tweeters
1x 10cm Woofer
Inputs1x 3.5mm jack
NetworkWi-Fi 6E
Bluetooth 5.3 (SBC, AAC, LD3)
Ethernet RJ45
StreamerChromecast
DLNA
Spotify Connect / Tidal Connect / Amazon Music Cast / Qobuz Connect
Compatible streaming services, web radios and protocolsSpotify
Deezer
Qobuz
Amazon Music
Tidal
Pandora
Napster
Apple Music
TuneIn iHeartRadioLinkPlay Radio
Compatible voice assistantsWiiM Home (iOS / Android)
Compatible voice assistantsAlexa
Google assistant
Siri
Supported audio formatsMP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Dimensions146 x 193 x 146mm (LHP)
Weight2.5kg
ColorWhite
Package1x WiiM Sound Display
The WiiM Sound Display is a connected speaker with a screen. It is a two-way speaker with a 100W amplification system powering its three speakers....
