By buying this product you get 52 loyalty points
The WiiM Sub Pro is an active connected subwoofer offering 250W of Class D power. It delivers deep, powerful bass and integrates seamlessly into the WiiM ecosystem thanks to its advanced connectivity. It features WiFi 6E connectivity, an RJ45 Ethernet port, and Bluetooth 5.3. In addition, thanks to the WiiM HOME app, the Sub Pro benefits from additional features such as a 10-band parametric EQ, cutoff frequency adjustment, automatic RoomFit calibration via AI, and more. Its anti-vibration chassis allows the 8" speaker to deliver powerful bass that is clean and controlled. Power management is also handled intelligently with an automatic standby mode and signal detection via the mono RCA or network input to optimize energy consumption.
With 250W of power at less than 1% THD+N and 104dB SPL sensitivity, the WiiM Sub Pro delivers an immersive experience whether used in a Hi-Fi, home theater, or video game setup. Its frequency range of 25Hz-200Hz and adjustable cutoff frequency ensure deep, clean bass. The Sub Pro's configuration, with an 8" speaker integrated into an anti-vibration enclosure, provides optimal performance.
The Sub Pro subwoofer offers extended wireless connectivity thanks to WiFi 6E and Bluetooth LE 5.3. It works perfectly with the WiiM ecosystem, particularly with WiiM Sound Display connected speakers, for a complete wireless system.
Numerous settings are available via the WiiM Home app. Precise equalization, crossover adjustment, phase control, latency customization, and subwoofer level adjustment allow you to tailor your experience for perfect sound reproduction according to your tastes and environment. In addition, AI-based room calibration (RoomFit™ Auto-Calibration) takes precise acoustic measurements to optimize performance based on the size of your room, the placement of your speakers, and your listening position.
The WiiM Sub Pro's intelligent power management allows it to automatically switch to standby mode and detect signals via the mono RCA or network input to optimize energy consumption.
| 1 | Front vent |
| 2 | Mains power supply |
| 3 | RJ45 port |
| 4 | Mono RCA input |
| 5 | Reset |
| Specifications | |
| Product type | Subwoofer |
| Speaker diameter | 8" (20.3cm) |
| Amplification type | Class D |
| Inputs | 1x RCA mono 1x Ethernet RJ45 WiFi 6E Bluetooth LE 5.3 |
| Power | 250Wrms @ 1% THD+N |
| Sensibility | 104dB SPL |
| Frequency response | 25–200Hz (±3dB from 30Hz to 200Hz) |
| WiFi | 802.11 b/g/n/ac/ax 2,4GHz, 5GHz et 6GHz |
| Compatible application | WiiM Home |
| General | |
| Dimensions | 399 x 301 x 322mm |
| Weight | 16kg |
| Color | White |
| Package | 1x WiiM Sub Pro 1x RCA cable 1x Power cable |
