WIIM SOUND LITE TWIN Connected Speaker Black (Pair)
Positioned as a variation on the Sound Display, the WiiM Sound Lite connected speaker offers all of its features, while providing 100 W amplification and support for high-resolution audio streams up to 24-bit/192 kHz, ensuring high-quality streaming.
Reference : 21411
499,00 €tax incl.
415,83 € tax excl.
WiiM Sound Lite Twin Connected Speaker 100W Black (Pair)
WIIM SOUND LITE photo
The little sister of the Sound Display, the WiiM Sound Lite connected speaker has the same features except that it does not have a screen and the remote control is not included. The Sound Lite has a 2-way design with two 1“ silk dome tweeters and a 4” paper cone woofer for detailed, balanced sound. With 100W of power and the ability to pair two speakers for true stereo sound, it can fill a fairly large space with sound. In addition, the AI RoomFit feature automatically adjusts the sound for consistent performance based on your room. The speaker is controlled via the WiiM Home app, which gives you access to more than 20 streaming services such as Spotify, Amazon Music, YouTube Music, TIDAL, Qobuz, Deezer, Napster, Pandora, Plex, SoundCloud, TuneIn, iHeartRadio, and many more. It is also compatible with Spotify Connect, TIDAL/Qobuz Connect, Alexa Cast, Google Cast, Roon, and DLNA network protocols and supports high-resolution streams up to PCM 24bit 192kHz.
WiiM Sound Lite: A 2-way architecture
The Sound Lite connected speaker features a premium 2-way acoustic architecture based on custom speakers that are independently tuned for the high and mid/low ranges via a precision filter, allowing each register to operate in its optimal zone to reduce distortion and ensure faithful timbre, rich detail, and long-lasting, fatigue-free listening. The system is based on a 4“ paper cone woofer, ensuring tight and natural mid-bass, combined with two 1” silk dome tweeters offering smooth, extended highs and wide dispersion, for a coherent, clear, refined and never aggressive soundstage.
The architecture of WIIM SOUND LITE
WiiM Sound Lite: AI RoomFit calibration
Thanks to AI RoomFit™ technology, the speaker automatically adjusts its sound reproduction to your listening environment. In just a few seconds using the WiiM Home app, the system analyzes the room's acoustics and the speaker's position using built-in microphones and your smartphone, then applies intelligent correction to achieve a balanced, natural, and enjoyable sound over time, without the need for complex settings or additional equipment.
Calibration of WIIM SOUND LITE
WiiM Sound Lite: Extended connectivity
The speaker gives you complete freedom in managing your music, centralizing access to more than twenty streaming platforms directly from the WiiM Home app, including Spotify, TIDAL, Qobuz, Amazon Music, Deezer, and YouTube Music. For those who prefer their usual apps, streaming is just as easy thanks to compatibility with Spotify Connect, TIDAL and Qobuz Connect, Alexa Cast, Google Cast, Roon, and the DLNA protocol, ensuring seamless integration with all audio uses and ecosystems.
Connectivity of WIIM SOUND LITE
WiiM Sound Lite: WiiM Home app
Smart presets give you instant access to your favorite playlists, radio stations, sources, or inputs with fully customized settings, including volume level, equalization, playback modes, and listening time. These presets also integrate with alarms and music routines, allowing you to program wake-up or relaxation times with the music of your choice, whether from streaming services or your local library, while precisely adjusting the time, volume, and playback time to suit your daily habits.WiiM Home application
Multiroom and Home Cinema function
WiiM Sound Lite: Multiroom and home theater
Designed for advanced multiroom use, the speaker allows you to synchronize music playback between multiple rooms or stream different content to each space, with precise control of volume and sources directly from the WiiM Home app, including for external audio inputs. The WiiM Sound Lite can also be integrated into a WiiM Dolby 5.1 home theater system, either as a main speaker or as a satellite, with the option of pairing two units in stereo and combining them with a WiiM Sub Pro subwoofer for an immersive and perfectly consistent soundstage.
WiiM Sound Lite speaker overview
Overview of the WiiM Sound Lite speaker
1RJ45 Ethernet port
2Power port
33.5mm jack input
4Volume +
5Previous track
6Volume -
7Next track
8Pause / Play
Product typeSmart speaker
Power supply100W
Speakers2x Tweeters
1x 10cm Woofer
Input1x Jack 3.5mm
NetworkWi-Fi 6E
Bluetooth 5.3 (SBC, AAC, LD3)
Ethernet RJ45
StreamerChromecast
DLNA
Spotify Connect / Tidal Connect / Amazon Music Cast / Qobuz Connect
Streaming service, web radios, and compatible protocolsSpotify
Deezer
Qobuz
Amazon Music
Tidal
Pandora
Napster
Apple Music
TuneIn iHeartRadio LinkPlay Radio
Compatible applicationWiiM Home (iOS / Android)
Compatible voice assistantsAlexa
Google assistant
Siri
Supported audio formatsMP3, AAC, ALAC, APE, FLAC, WAV, WMA, OGG
Dimensions146 x 193 x 146mm (LHP)
Weight2.5kg/speaker
Package2x WiiM Sound Lite connected speaker
2x 3.5 jack to RCA stereo cable
2x Power cable
WIIM SOUND LITE TWIN Connected Speaker 100W Black (Pair)
Positioned as a variation on the Sound Display, the WiiM Sound Lite connected speaker offers all of its features, while providing 100 W...
