WIIM SUB PRO Connected Active Subwoofer Black (Unit)
The WiiM Sub Pro is an active connected subwoofer offering 250W of Class D power. It delivers deep, powerful bass and integrates seamlessly into the WiiM ecosystem thanks to its advanced connectivity. It features WiFi 6E connectivity, an RJ45 Ethernet port, and Bluetooth 5.3.
By buying this product you get 52 loyalty points
Reference : 21175
529,00 €tax incl.
440,83 € tax excl.
Shipping date: 17-11-2026.
WiiM Sub Pro Connected Active Subwoofer WiFi 6E Bluetooth 5.3 250W 25Hz-200Hz Black (Unit)
Photo du WIIM SUB PRO
The WiiM Sub Pro is an active connected subwoofer offering 250W of Class D power. It delivers deep, powerful bass and integrates seamlessly into the WiiM ecosystem thanks to its advanced connectivity. It features WiFi 6E connectivity, an RJ45 Ethernet port, and Bluetooth 5.3. In addition, thanks to the WiiM HOME app, the Sub Pro benefits from additional features such as a 10-band parametric EQ, cutoff frequency adjustment, automatic RoomFit calibration via AI, and more. Its anti-vibration chassis allows the 8" speaker to deliver powerful bass that is clean and controlled. Power management is also handled intelligently with an automatic standby mode and signal detection via the mono RCA or network input to optimize energy consumption.
WiiM Sub Pro: A powerful subwoofer
With 250W of power at less than 1% THD+N and 104dB SPL sensitivity, the WiiM Sub Pro delivers an immersive experience whether used in a Hi-Fi, home theater, or video game setup. Its frequency range of 25Hz-200Hz and adjustable cutoff frequency ensure deep, clean bass. The Sub Pro's configuration, with an 8" speaker integrated into an anti-vibration enclosure, provides optimal performance.
La connectivité du WiiM SUB PRO
WiiM Sub Pro: Extended connectivity
The Sub Pro subwoofer offers extended wireless connectivity thanks to WiFi 6E and Bluetooth LE 5.3. It works perfectly with the WiiM ecosystem, particularly with WiiM Sound Display connected speakers, for a complete wireless system.
WiiM Sub Pro: Total control via the WiiM HOME app
Numerous settings are available via the WiiM Home app. Precise equalization, crossover adjustment, phase control, latency customization, and subwoofer level adjustment allow you to tailor your experience for perfect sound reproduction according to your tastes and environment. In addition, AI-based room calibration (RoomFit™ Auto-Calibration) takes precise acoustic measurements to optimize performance based on the size of your room, the placement of your speakers, and your listening position.
Contrôle du WiiM SUB PRO
WiiM Sub Pro: Intelligent power management
The WiiM Sub Pro's intelligent power management allows it to automatically switch to standby mode and detect signals via the mono RCA or network input to optimize energy consumption.
Gestion de l'alimentation du WiiM SUB PRO
WiiM Sub Pro overview
Aperçu du WiiM SUB PRO
1Front vent
2Mains power supply
3RJ45 port
4Mono RCA input
5Reset
Product typeSubwoofer
Speaker diameter8" (20.3cm)
Amplification typeClass D
Inputs1x RCA mono
1x Ethernet RJ45
WiFi 6E
Bluetooth LE 5.3
Power250Wrms @ 1% THD+N
Sensibility104dB SPL
Frequency response25–200Hz (±3dB from 30Hz to 200Hz)
WiFi802.11 b/g/n/ac/ax 2,4GHz, 5GHz et 6GHz
Compatible applicationWiiM Home
Dimensions399 x 301 x 322mm
Weight16kg
Package1x WiiM Sub Pro
1x RCA cable
1x Power cable
WIIM SUB PRO Connected Active Subwoofer WiFi 6E Bluetooth 5.3 250W 25Hz-200Hz Black (Unit)
The WiiM Sub Pro is an active connected subwoofer offering 250W of Class D power. It delivers deep, powerful bass and integrates seamlessly into...
