Marc C.
Bertrand j.
Ramiro F.
Find on our website our complete range of adapters for all types of connections: RCA, Jack, XLR, Toslink Optics, Antenna / Sat, HDMI, etc...
Whatever the problem you are facing in your installation, you will find the solution here among all our adapters.
Discover here our wide choice of RCA adapters, allowing you to switch from RCA male to RCA female, or from RCA to BNC. Among our range, you will also find RCA "Y" adapters, which are nothing more and nothing less than audio splitters that double the signals.
We offer you a very wide range of Jack adapters, in fact these can be declined in a very large number of references. Stereo or mono jack adapters, gold-plated or unplated, male or female. You will also find DC jack adapters to screw terminals for power supplies. A wide range of applications and uses are covered with our jack adapters.
In our toslink optical adapter category, discover optical to coaxial converter adapters for SPDIF connection. You will also find Optical Toslink to Mini Toslink adapters for devices using this connection, such as the SMSL AD18 full digital amplifier.
Maybe you need an HDMI adapter? Find in this category all the HDMI adapters you need! Whether HDMI Male or Female, or Micro HDMI or Mini HDMI, all options are available to you to solve your HDMI connectivity problems.
Very often in the audio world, you will come across jack and RCA connectors, and these can be used together very well. In particular, you will need Jack / RCA adapters in order to connect together several devices that do not have exactly the same connectors. Our wide range of RCA to Jack adapters will allow you to connect these devices together in a clean and professional way.
Jack to XLR adapters may be required in some rare cases of device connectivity. That's why we offer you these different XLR to Jack adapters, meeting the needs of the most demanding audiophiles.
XLR and RCA connectors are widely used in the audio industry. We find this connection on a very large number of devices, so what could be more normal than to propose RCA to XLR adapters to allow these devices to connect to each other.
Our range of Antenna Adapters offers you products adapted to the needs encountered in the connection of antenna cables. For example, a male to female angled antenna adapter will be useful if the space available behind your TV is limited.
There are various adapters of all types and all kinds, so vast is the world of connectors. You will find in this category many adapters covering many fields and applications. For example adapters for MMCX EMI, or RCA to DIN adapters.
USB adapters are essential for many devices with this connection. The USB standard is available in many variants, such as USB-B, USB-A, or more recently USB-C (also known as USB Type C). Micro-USB to USB-A adapters are widely used for smartphones or computers.
The power plugs are not the same in different countries and continents, that's why power plug adapters are in great demand and available in many references.
The most common standard in Europe is the Schuko plug, so you can find Schuko to NEMA 5-15P or IEC to Schuko plug adapters in our range, and many other models.
