2SC5200 / 2SA1943 Mono Class AB Amplifier Boards 250W 4 Ohm (Pair)
These mono power amplifier modules deliver 250W of power at 4Ω. The amplification stage consists of 6 high-quality Toshiba 2SC5200 / 2SA1943 bipolar transistors, while the power supply section includes two ELNA 63V 10000µF capacitors, a Sanken 50A diode bridge (rectifier) and a DIP8-mounted TL072CP dual OPA.
4.7 / 5
Reference : 17869
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 23-09-2025.
This product is delivered with the heatsink unassembled.
2SC5200 / 2SA1943
2SC5200 / 2SA1943 Module Amplificateur Mono Class A/B 250W / 4 Ohm (La paire)
These mono power amplifier modules deliver 250W of power at 4Ω. The amplification stage consists of 6 high-quality Toshiba 2SC5200 / 2SA1943 bipolar transistors, while the power supply section includes two ELNA 63V 10000µF capacitors, a Sanken 50A diode bridge (rectifier) and a DIP8-mounted TL072CP dual OPA. In addition, two driver transistors (C2073 and A940) power the bipolar transistors, while a 669A heat regulation transistor located on the heat sink ensures their thermal stability. These amplifier modules have a wide frequency response of 10Hz - 50kHz and a low distortion of 0.002%. Input voltages range from 18-0-18VAC to 38-0-38VAC.
This pair of amplifier modules is ideal for DIY projects involving high-power amplification and high-fidelity sound. They deliver a transparent, detailed and powerful sound, ideal for creating a dual-mono amplifier.
The quiescent current must be set to 15mV at the test points, using the blue potentiometer (W 202).
Speaker protection
Ce module d'amplification mono de 250 W de classe A/B intègre également une protection contre les retards de commutation et une protection contre le courant continu pour protéger vos haut-parleurs.
1Mono input (solder pads)
2A940 transistor (driver)
3Dual TL072CP OPA (DIP8)
450A diode bridge (rectifier)
518-0-18V AC to 38-0-38V AC Power supply input (screw terminal)
6Speaker output (screw terminal)
7ELNA 63V 10000µF capacitors
8Voltage test terminal for heat compensation transistor adjustment (solder pads)
93x Toshiba 2SA1943 power transistors
10669A Heat compensation transistor
11Potentiometer W202 (quiescent current adjustment)
123x Toshiba 2SC5200 power transistors
13C2073 transistor (driver)
144x 63V 120µF capacitors
Inputs & Outputs
1Line input +
2Line input GND
3AC power supply input
40-GND power supply input
5AC power supply input
6Speaker output -
7Speaker output +
Product typePower amplifier modules
Amplification typeClass AB
Power transistorsToshiba BPN bipolar transistors:
3* 2SC5200
3* 2SA1943
Diver stage transistors1* C2073
1* A940
Regulator transistor (thermal compensation)1* 669A
OPADual OPA TLTL072CP (DIP8)
Capacitors2* ELNA 63V 10000µF
4* KZN 63V 120 µF
Output power250W @ 4Ω
150W @ 8Ω
Frequency response10Hz-50kHz
Distortion0.002%
Input1* Mono input on solder pads
Output1* Speaker output on speaker terminal
Power supply18-0-18V to 38-0-38V AC onscrew terminal
PCB dimensions (D*W*H)Aprox. 82*205*54mm
Dimensions with heatsink (D*W*H)Approx. 122*212*63mm
Mounting holes spacingApprox. 69*192.5mm
Weight890g/module
QuantitySold in pairs
InputScrew terminals
InputSolder pad
OutputScrew terminals
ChannelDual Mono
Channel1 (Mono)
ClassClass A / AB
Amplifier chipTransistors
Power (W)250.0
3 reviews
Modules sympas.
Je ne vais pas juger la conception du produit, je n'y connais pas grand chose. En pratique, on peut se faire un montage double mono propre et net vu que chaque module intègre son alimentation et sa protection HP. Vous ajoutez un ou deux transfo, un softstart, les connexions et c'est tout, pas trop de fils dans tout les sens. Dans mon cas, chaque module est alimenté par un transfo de 250 VA, 35 V après un softstart qui permet l'allumage/extinction. Après montage et première mise en route, j'ai constaté qu'il chauffait pas mal et je n'ai pas utilisé les radiateurs fournis (réutilisés ailleurs) et je l'ai monté en coffret (hifi 2000) avec dissipateurs. Autre petit détail, pensez à diminuer la valeur de la résistance ajustable avant la première mise sous tension car la tension peut être très élevée, vous économiserez quelques fusibles.
This review has been posted for 2SC5200 / 2SA1943 Mono Class AB Amplifier Boards 250W 4 Ohm (Pair)
A60 puis A60+
Il existe une version avec un plus grand nombre de transistors de puissance, permettant de piloter du 4 ohms sans soucis, et avec un bon taux d'amortissement. Avez-vous prévu de commercialiser ces modules ? Si oui, je commande directement 3 kits pour mon filtrage actif !
Modules avec du potentiel
Point négatifs:
- Pourquoi diable des modules en miroir ? Pratique quand on met les deux amplis dans un seul coffret. Mais pas pratique quand on fait deux coffrets. Quid de la stricte équivalence des modules ?
- L'aigu pas assez précis à mes oreilles, balance subjective tonale trop grave ? Peut être lié à la classe de fonctionnement ?
Points positifs:
- Le double mono a une image sonore très aéré et précise dans les basses et médiums.
- La tenue des hauts-parleurs est bonne dans le grave. Mes deux 12" par enceinte sont bien pilotés dans les graves.
Par curiosité pour écouter car il y avait le schéma qui montre une contre réaction en courant et pas de condensateur sur le circuit de contre réaction et en plus des circuits cascodes. Je m'attendais à de meilleurs aigus, trop métallique à mon goût, mais c'est peut être lié à la classe de fonctionnement des transistors de sortie, qu'on ne les fassent pas plus travailler en classe A ? Possible avec de plus gros radiateurs...
Du potentiel donc !
These mono power amplifier modules deliver 250W of power at 4Ω. The amplification stage consists of 6 high-quality Toshiba 2SC5200 /...
