AMP8950-2X120 Amplifier Module Class D TDA8950 2 x 120W 4 Ohm
This amplifier module AMP8950-2X120 in Class D is based on an amplifier chip TDA8950. This allows it to develop no less than 2 x 120W while offering a high efficiency of 90%, while ensuring low consumption.
Reference : 12952
54,90 €tax incl.
45,75 € tax excl.
AMP8950-2X120
Amplifier Module Class D TDA8950 2x120W 4Ω
Module Amplificateur Class D 2x120W 4Ohm
This amplifier module AMP8950-2X120 in Class D is based on an amplifier chip TDA8950. This allows it to develop no less than 2 x 120W while offering a high efficiency of 90%, while ensuring low consumption. The integration of MOS tubes allows this module to offer quality reproduction by developing deep bass and a beautiful dynamic. In addition, the metal resistors with an accuracy of ±1% ensure a good Signal/Noise Ratio while the two electrolytic capacitors of 10000µF of the main circuit ensure a stable and clean signal.
In addition, this amplifier module also embeds a UPC1237 circuit to effectively protect your speakers and the TDA8950 chip embeds protections against overvoltages, overloads and high temperatures.
This AMP8950-2X120 module offers a 3 pin connector input that will allow you to associate the desired module. It also includes a 50K potentiometer to adjust the volume level.
Amplifier chipTDA8950
Amplifier typeClass D
Power2x120W 4Ω
Rendement90%
Input3 pins connector
Electrolytic capacitor2x Nover Audio Grade 10000µF 50VDC
Power supply18V à 26V AC
Dimensions138 x 78 x 49mm
Weight230g
PCB ColorRed
InputScrew terminals
OutputScrew terminals
Channel2 (Stereo)
Power (W)120.0
This amplifier module AMP8950-2X120 in Class D is based on an amplifier chip TDA8950. This allows it to develop no less than 2 x 120W while...
