Class D Mono TPA3110 30W 4 Ohm
This small mono Class D amplifier module is based on a TPA3110 chip, allowing it to develop a maximum power of 30W. Simple and compact, it allows the development of small amplified audio systems.
It is recommended to use a power supply voltage between 12V and 15V for a 4Ω speaker and between 12V and 20V for an 8Ω speaker.
| Specifications | |
| Product type | Amplifier board |
| Amplifier type | Class D |
| Amplification chip | TPA3110 |
| Input | Screw terminal |
| Output | Screw terminal |
| Output power | 1x30W |
| Efficiency | 93% |
| Frequency response | 35Hz - 88kHz |
| General | |
| Supply voltage | 10-24VDC 3A |
| Dimensions | 55 x 40 x 15mm |
| Mounting holes spacing | 47.5 x 33mm |
| Input | Screw terminals |
| Output | Screw terminals |
| Channel | 1 (Mono) |
| Class | Class D / T |
| Amplifier chip | TPA3110 |
| Power (W) | 30.0 |
