Amplifier Module Bluetooth 5.0 USB-C Volume Control 2x20W 4 ohms
This amplifier module is a complete solution offering numerous operating possibilities. It features Bluetooth, USB-C Audio (16bit 44.1kHz), and 3.5mm AUX inputs.
Reference : 22039
6,90 €tax incl.
5,75 € tax excl.
Amplifier Module Bluetooth 5.0 USB-C Volume Control 2x 20W 4 Ohms
Amplifier Module
This amplifier module is a complete solution offering numerous operating possibilities. It features Bluetooth, USB-C Audio (16bit 44.1kHz), and 3.5mm AUX inputs. It also integrates a volume control with rotary knob, and audio output can be delivered either through a 3.5mm jack for headphone listening or via screw terminals with an amplification power of 2x 20W into a 4-ohm load. Versatile, this DIY module will fit perfectly into a desktop setup, especially since the included small PCB panels allow direct use without an aluminum enclosure.
Warning: output power depends on the power supply used.
The Bluetooth input has priority over USB and the 3.5mm jack. USB has priority over the 3.5mm jack.
The volume control does not manage the source device volume.
Amplifier Module Overview
1Amplified output via screw terminal
2USB-C Audio input
312-24V DC power supply
4Bluetooth antenna
5Volume control / Play / Pause
63.5mm AUX jack input
73.5mm audio output
Technical Specifications
Product typeAmplifier module
InputsBluetooth 5.0
1x USB-C
1x 3.5mm Jack
Outputs1x Amplified output via screw terminal
1x 3.5mm jack output
Output power2x 20W @ 4 Ohms
Supported sampling rateUSB-C: 16bit 44.1kHz
Power supply12-24V DC (Jack DC 5.5/2.1mm)
DimensionsPCB: 52 x 52mm
Weight4g
Package contents1x Amplifier module
1x Plastic rotary volume knob
1x DC jack to bare wire adapter
2x PCB enclosure plates
4x Standoffs + Screws
1x Black screws
1x Screwdriver
InputJack 3.5mm
OutputScrew terminals
OutputJack 3.5mm
Channel2 (Stereo)
Amplifier chipN/A
Power (W)20.0
This amplifier module is a complete solution offering numerous operating possibilities. It features Bluetooth, USB-C Audio (16bit 44.1kHz), and...
