Amplifier Module 2.1 Class D TPA3116 2x 50W + 100W with Volume / Tone / Crossover Frequency Controls
This 2.1-channel Class D amplifier module is based on the use of two TPA3116D2 amplifier chips. It is therefore capable of delivering up to 2x50W + 100W, enabling 2.1-channel audio amplification with a passive subwoofer.
Reference : 22037
34,90 €tax incl.
29,09 € tax excl.
Shipping date: 17-11-2026.
Amplifier Module 2.1 Class D TPA3116 2x 50W + 100W Bluetooth 5.0 with Volume / Tone / Crossover Frequency Control
TPA3116D2 2.1 Class D Amplifier Module
This 2.1-channel Class D amplifier module is based on the use of two TPA3116D2 amplifier chips. It is therefore capable of delivering up to 2x50W + 100W, enabling 2.1-channel audio amplification with a passive subwoofer. It offers numerous adjustment options via 5 potentiometers, including volume control, treble tone adjustment, treble level (high-pass), crossover frequency, and bass level (low-pass). It provides 2 input options (via a 3.5mm AUX jack or Bluetooth 5.0). Outputs are available through screw terminals for all 3 channels. As an added feature, solder pads allow remote mounting of the volume control, playback controls, operating mode selection, and more. The module can be powered via a DC jack or screw terminal block and accepts 12-24V DC 3A/4A.
Output Power of the TPA3116D2 2.1 Class D Amplifier Module
Overview of the TPA3116D2 Bluetooth Amplifier Module
1Bluetooth Antenna
23.5mm AUX Jack Input
3Right channel output via screw terminal
4Left channel output via screw terminal
5Subwoofer output via screw terminal
612-24V DC 3A Power Supply
7Bass level (Low-Pass)
8Bass crossover frequency 0-200Hz
9Treble level (High-Pass)
10Crossover frequency On/Off Switch
11Treble tone control
12Volume control potentiometer / source selection button
13Solder pads for external control interface (Bluetooth only)
Technical Specifications
Product TypeClass D amplifier module
Channels2.1
Amplifier Chip2x TPA3116
Inputs1x 3.5mm AUX Jack
Bluetooth 5.0
Outputs1x Right Channel Output via Screw Terminal
1x Left Channel Output via Screw Terminal
1x Subwoofer Output via Screw Terminal
Output Power2x 50W + 100W
Output ImpedanceL/R: 4-8 Ohms
Sub: 2-8 Ohms
Low-Pass Filter Crossover Frequency0-200Hz
Frequency Response20Hz-20kHz
Input Sensitivity600-800mV
Power Supply12-24V DC 3A/4A (via 5.5/2.1mm DC jack or screw terminal block)
DimensionsPCB: 100 x 100mm
Weight140g
Package Contents1x TPA3116D2 Bluetooth 2.1 Class D Amplifier Module
5x Potentiometer Caps
5x Nuts + Washers
4x Spacers
4x Screws
InputJack 3.5mm
OutputScrew terminals
Channel2.1
Amplifier chipTPA3116D2
Power (W)100.0
Power (W)50.0
This 2.1-channel Class D amplifier module is based on the use of two TPA3116D2 amplifier chips. It is therefore capable of delivering up to 2x50W +...
