ARYLIC UP2STREAM AMP 2.1 Amplifier Module 2.1 WiFi Bluetooth 5.0 Tone Control 2x50W + 100W
The Arylic Up2Stream Amp 2.1 is a 2.1 channel amplifier with full wireless connectivity. It will allow you to use a subwoofer while enjoying the convenience of audio streaming. It supports WiFi, Bluetooth 5.0, DLNA, UPnP, AirPlay and Spotify Connect. The module's clever and smart design also ensures accurate and detailed sound reproduction.
4.7 / 5
Reference : 14710
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 12-06-2026.
Up2Stream Amp 2.1
2.1 Amplifier Module WiFi DLNA Bluetooth 5.0 Tone Control 2x50W + 100W
Up2Stream Amp 2.1 Module Amplificateur 2.1 WiFi DLNA Bluetooth 5.0 Contrôle de Tonalité 2x50W + 100W
The module also offers a physical connection with an Ethernet RJ45 input, a USB-A connector (USB Host), a 3.5mm jack and a Micro USB.
Volume and tone control
The amplifier embeds a series of 3 buttons. The first one will allow you to adjust the volume level, the two others will adjust the bass and treble according to your listening and your audio system.
One of the few 2.1 and WiFi amplifiers
Currently, it is difficult to find an amplifier that is both 2.1-channel and supports wireless transmission, especially WiFi, and is also in this price range. The Arylic Up2Stream Amp 2.1 fills this gap and does it brilliantly.
Filtering
The AMP2.1 module has a filter function with a high pass filter on its stereo output / low pass filter on its mono output.
The default cutoff frequency is 110Hz and can be set from 50Hz to 200Hz by long pressing the Treble (30Hz increment) and Bass (30Hz decrement) buttons.
A very precise equalizer
While the bass and treble levels can be adjusted via the buttons on the module or via a remote control (sold separately), free software is also provided. ACPWorkbench thus allows a more precise equalization thanks to its graphical interface.
Many streaming services
The amplifier is compatible - via its mobile application 4Stream - with many streaming services. You can simply stream remotely from Spotify, Deezer, Qobuz, Tidal, Napster, Amazon Music, Pandora, iHeart Radio or web radios.
Multiroom
The Arylic Up2Stream Amp 2.1 allows you to easily and quickly set up an efficient multiroom system, directly controlled from your smartphone. Each module appears within the mobile application and can be controlled individually or synchronized.
Android & iOS App
The free 4Stream mobile application, available for both Android and iOS smartphones, will allow you to easily and remotely control all your Arylic Up2Stream Amp 2.1 modules.
Application 4Stream Android Application 4Stream iOS
Arylic support chart
Compatibilité des modules Arylic
Product typeAmplifier module
Power2x50W @ 4Ω + 100W @ 2Ω, BTL, 24V
2x30W @ 8Ω + 75W @ 4Ω, BTL, 24V
2x22W @ 8Ω + 48W @ 4Ω, BTL, 19V
2x15W @ 8Ω + 30W @ 4Ω, BTL, 15V
Inputs1x Jack 3.5mm
1x 4 Pins connector
1x Micro USB
1x Ethernet RJ45 10/100M
1x USB-A (USB Host)
Output1x Connector for speakers and subwoofer (pins spacing : 5mm)
ConnectivityWiFi (IEEE802.11 b/g/n 2.4G)
Bluetooth 5.0 (SBC/AAC)
DLNA
UPnP
AirPlay
Spotify Connect
QPlay
Bluetooth transmission distance10m
Supported streaming servicesSpotify
Deezer
Qobuz
Tidal
Amazon Music
Napster
Webradios
Pandora
iHeart Radio
Volume control
Tone controlVia buttons, remote control (sold separately) or ACPWorkbench software :
Bass and Treble
THD< 0.03% @ 1kHz / 1W / 24V / 4Ω
Speakers impedance4-8Ω
Supported file formatsFLAC, MP3, AAC, AAC+, ALAC, APE, WAV
Supported sampling ratesPCM up to 24bit 192kHz
Tension d'alimentation12-24V DC
Dimensions124 x 100 x 25mm
Package1x Arylic Up2Stream Amp 2.1
1x 6 Pins connector
1x WiFi antenna
3x Knob cover
1x Screwdriver
InputRJ45
InputWiFi
InputJack 3.5mm
OutputSpeaker terminal
Channel2.1
Amplifier chipN/A
Power (W)100.0
Power (W)50.0
3 reviews
Good sound, unstable Wi-Fi, both with Wi-Fi and cable. Volume changes on its own, I didn't understand why, I change volume and it's never instantaneous, the device appears and disappears on the iPhone's Airplay even when connected by cable, I have to turn it off and on to make it appear, there is no anti-pop function, it pops when it is turned on and off power supply, lots of bugs just consult the forum, good for those who like to look for problems.
This review has been posted for ARYLIC UP2STREAM AMP 2.1 Amplifier Module 2.1 WiFi Bluetooth 5.0 Tone Control 2x50W + 100W
Super pour une enceinte 3 voies actives
Je l'ai utilisé pour fabriquer une enceinte active grâce au DSP intégré qui permet de configurer des filtres indépendants pour chaque canal (tweeter, medium, Sub). Détails in English ICI:
https://www.diyaudio.com/community/threads/3-ways-active-speakers-boombox-bluetooth-wifi-with-arylic-amp-2-1.384549/#post-6979277
Very good for small diy projects
I coupled this board to an SMPS300RS regulated power supply, feeding it with clean and adequate power at 24V. Overall the board does what it advertises and the build quality is very good, with the exception of the cheap plastic knobs. I would only review the sound quality which, although powered by a decent supply, is subpar to entry HiFi standards, do not expect do get a sound like a decent inexpensive integrated amp, The class D circuity implemented in this board lacks clarity and instrument separation, sound thick overall. I compared this board sound to a TEAC integrated class D amp I have rated at 2X20W @ 8 ohm using ICEPOWER 2X50W 4 ohm circuity, and the TEAC win hands down. Also this board has an integrated DAC with DSP capabilities, as shipped the sound seems too bright and I needed to reduce treble way down to be at an acceptable no fatiguing level. Also the bass seemed elevated, so overall I guess a U type of preset is available boosting lower and higher frequencies. In order to be able to tune the DSP settings yourself you need to purchase a $20 software that gives you access to the internals of the DSP of the DAC. I do not have this at the moment but its a must if you are serious about music quality. Overall 4 stars, the one star missing is for the amp section of this amp that is lacking, but as they say you should not expect so much for a €95 board, it is a very good choice for TV bars or Bluetoorh style small speaker.
The Arylic Up2Stream Amp 2.1 is a 2.1 channel amplifier with full wireless connectivity. It will allow you to use a subwoofer while enjoying the...
