Class D 2x30W Bluetooth aptX + Extension
Audiophonics offers you an audio amplifier set for all types of furniture integration. This set includes a Bluetooth 4.0 aptX Class D stereo amplifier module that delivers 2x30W under 8Ω, associated with an Aluminium front panel with a volume control knob, 2 USB-A charging ports, a power button and a 3.5mm jack input.
This Bluetooth 4.0 aptX amplifier will allow you to listen to your favorite songs on your Bluetooth audio systems such as smartphone, tablet, iPhone, iPad... The 3.5mm jack port will also allow you to stream music directly to your amplifier via any source with a 3.5mm jack connection.
The Aluminium front panel with the different knobs and settings available allows you to integrate the unit into a piece of furniture or any other space: kitchen, living room, outside.
You can imagine this set integrated into your kitchen furniture, and at the end of the amplifier, 2 vibrators excite accepting a power of 2x30W under 8Ω. An integration in a motor home, a caravan or any other habitable vehicle is also possible. The loudspeaker terminals at the output of the amplifier are compatible with any loudspeakers.
This set was imagined, designed and assembled in our workshops in France, in Bordeaux.
| Specifications | |
| Product type | Amplifier |
| Amplification chip | TPA3118 |
| Power | 2x30W @ 8Ω (THD+N < 1%) |
| Frequency response | 20Hz - 20kHz |
| Bluetooth version | 4.0 |
| Supported Bluetooth codec | aptX, +EDR, A2DP |
| LED status indicator | |
| Protections | Surintensités Surchauffe |
| Extension interface connectivity | 2x USB-A plugs for smartphone charging with BC 1.2 protocol 1x Jack 3.5mm input |
| Extension interface buttons | Volume button ON/OFF button (with LED) |
| General | |
| Power supply | 19VDC 3.4A via Jack Dc 5.5/2.5mm (power supply) |
| Case material | Aluminium and Plexiglas |
| Color | Amplifier: Black Extension plate : Silver |
| Amplifier terminals | Acrylic, Gold plated contacts Compatible with bananes plugs, spades and bare wires |
