Amplifier Module 2.1 Class D TPA3116 2x50W + 100W with Volume / Tone / Crossover Frequency Controls
This 2.1-channel Class D amplifier module is based on the use of two TPA3116 amplifier chips. It is therefore capable of delivering up to 2x50W + 100W, enabling 2.1-channel audio amplification with a passive subwoofer.
Reference : 22035
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 17-11-2026.
2.1 Class D Amplifier Module TPA3116 2x 50W + 100W with Volume / Tone / Crossover Frequency Control
This 2.1-channel Class D amplifier module is based on the use of two TPA3116 amplifier chips. It is therefore capable of delivering up to 2x50W + 100W, enabling 2.1-channel audio amplification with a passive subwoofer. It offers numerous adjustment options via 5 potentiometers, including volume control, treble tone control, treble level (high-pass), crossover frequency, and bass level (low-pass). It features a selection of 2 analog inputs (via 3-pin connector and 3.5mm AUX jack). Output connections are provided through screw terminals for all 3 channels. As an added bonus, a V-OUT output allows powering an additional module with up to 5V 120mA. Furthermore, the module can be powered via a DC jack or screw terminal block and accepts 12-24V DC 3A.
Overview of the 2.1 TPA3116 Amplifier Module
1DC 12-24V 3A Power Supply
2Right Channel Output
3Left Channel Output
4Subwoofer Output
53-Pin PCB Connector Input
63.5mm AUX Jack Input
75V 120mA Auxiliary Power Output
8Bass Level (Low-Pass)
9Bass Crossover Frequency 0-200Hz
10Treble Level (High-Pass)
11Crossover Frequency On/Off Switch
12Treble Tone Control
13LED Solder Pads
14Volume Control
Technical Specifications
Product TypeClass D Amplifier Module
Channels2.1
Amplifier Chip2x TPA3116
Inputs1x 3-pin PCB Connector
1x 3.5mm AUX Jack
Outputs1x Right Channel Output via Screw Terminal
1x Left Channel Output via Screw Terminal
1x Subwoofer Output via Screw Terminal
Output Power2x 50W + 100W
Output ImpedanceL/R: 4 Ohms
Sub: 3-4 Ohms
Low-Pass Filter Crossover Frequency0-200Hz
Power Supply12-24V DC 3A (Jack DC 5.5/2.1mm)
DimensionsPCB: 100 x 100mm
Weight170g
Package Contents1x 2.1 Class D amplifier module TPA3116
5x Potentiometer knobs
1x 3-pin connector cable
4x Spacers
4x Screws
InputJack 3.5mm
InputPCB Connector
InputSolder pad
OutputScrew terminals
Channel2.1
Amplifier chipTPA3116
Power (W)100.0
Power (W)50.0
Très bien pour dépanner un ancien kit 2.1
Parfait pour remettre en service un ancien kit 2.1 dont la carte électronique d'origine avait lâché. À installer dans un boîtier adapté, sans oublier de prévoir une ouïe de ventilation pour le radiateur. Le caisson de basses, débarrassé de son électronique est devenu passif et se raccorde au bornier arrière de la carte.
This review has been posted for Amplifier Module 2.1 Class D TPA3116 2x50W + 100W with Volume / Tone / Crossover Frequency Controls
This 2.1-channel Class D amplifier module is based on the use of two TPA3116 amplifier chips. It is therefore capable of delivering up to 2x50W +...
