TI Purepath HD 150 Amplifier Module Class D TPA3255 2X150W 8 ohm
LME49810 2SC5200 Amplifier board 300W 8 ohm Mono (1 unit)
Reference : 12305
79,00 €tax incl.
65,83 € tax excl.
Available
Shipping date: 25-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Amplifier Module TPA3255
- Class D 2x150W sous 8 Ohms -
amplificateur TPA3255
TI : TPA 3255 Purepath
This module integrates the latest generation of Texas Instrument Purepath UltraHD technology with 100kHz bandwidth in HD audio formats. The integrated mosfet scanning error correction system allows accurate playback on a module with high power of 2X150W at 8 Ohm on a compact and simple integration board.
The input stage designed on two classic PDOs TL072 type FET works on an input voltage of 2V. It is possible to directly attack by a DAC with variable volume or by digital volume of a computer without dynamic adaptation and bandwidth problems.
High quality parts
The module has 2 ELNA ELA 5 electrolytic capacitors of 3900µF on 100V of high reliability to ensure a constant power supply. The control part uses the high-performance LM2575HVS. The output filter has audio inductances for smoother sound.
The LEDs on the circuit indicate the following functions:
Fault: Signal too high at input or output impedance on speaker terminals too high
OTW Clip: Overvoltage and under voltage and overheating
This module require a speaker delay board to avoid ON/OFF plop noise
Technical caracteristics
  • amplifier chips : TPA3255
  • Class D type
  • effeciency : 90%
  • frequencey response : 20Hz - 20kHz
  • Nominal power : 2x150W (8 Ohms)
  • Output power max : 2 x 315W (4 Ohms)
  • Dynamic range : 100dB
  • Noise ratio : 111dB
  • Stanby Current : 60mA
  • Voltage : DC 48/50V
  • Dimensions : 150 x 93mm
ComponentTPA3255
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
