WONDOM AA-AB31282 1 x 200 Watt Class D Audio Amplifier Board - T-AMP
Reference : 10971
42,00 €tax incl.
35,00 € tax excl.
This T-AMP Class D mono compact amplifier module is of tremendous efficiency: it delivers 200W under 3 Ohms integrated heat sink originally thanks to the design of its PCB.
Ideal for all types of DIY projects, it can be integrated easily into your audio systems thanks to its simplified implementation for the design of a subwoofer or active speakers for example.
This Sure Electronics 1x200W amplifier features multiple ESD protectors and peak voltages to ensure robustness and reliability.
It has a DC 5.5 / 2.5mm input for 15 / 36V DC power supply.
A PDF is available in the download tab.
Characteristics :
  • Amplifier T-AMP.
  • Architecture Class D.
  • PBTL topology.
  • Excellent audio quality in a compact format.
  • Line level input (2VRMS) on RCA.
  • Protection against over-current and overheating.
  • Protection Hp ("plocs").
  • Power: 150W @ 3 ohm (<0.1% THD + N), 200W @ 3 ohm (<10% THD + N).
  • Input impedance: 10K ohm.
  • Input Sensitivity: 1.8Vrms.
  • Frequency response: 20Hz - 20kHz to +/- 3dB.
  • Operating temperature: 0 to 50 ° C.
  • Yield: 93%.
  • Power Requirements: 9 to 34VDC (34V recommended) / DC Jack 5.5 / 2.5mm.
  • Dimensions: 100x68x15mm.
  • Weight: 375g.
OutputScrew terminals
Channel1 (Mono)
Amplifier chipN/A
Power (W)200.0
