WONDOM AA-JA32472 JAB2-30 V2 Class D Stereo Amplifier Module Bluetooth 5.0 DSP 2x30W 8 Ohm
Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use.
4.7 / 5
Reference : 13308
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 31-12-2025.
SURE-AA JA32171 V2
Class D Stereo Amplifier Module 2x30W 8 Ohm DSP Bluetooth 5.0 and Antenna
JAB2
Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use. They are thus designed to operate on battery power as well as AC. For this purpose the power supply can be battery, AC adapter, solar panels (see PDF in the download tab).
There are many possibilities for designing amplifier / powered speakers: yachting, small sound system, jukebox, home automation, motorhome, In-Wall or ceiling speakers. And more generally, any project requiring flexibility in the integration of the amplifier.
Version V2 : external antenna for bluetooth
This is the V4 version of JAB2-30 which now includes a external Bluetooth antenna with adhesive. This enhancement facilitates a clean integration in housing, without sacrificing on the quality of the transfer. Thus, all Bluetooth applications are gaining flexibility and JAB2 can now be used to develop a high performance Bluetooth dock, active speakers apt-X compatible with wireless apt-X tablets or smartphones.
In addition, this new version adds a 2-pin connector, allowing you to block Bluetooth pairing mode once the connected person disconnects, or to enable or disable pairing mode as you wish. For this purpose, a button is delivered with the module. A short press on the latter allows you to automatically block the appearance when a user disconnects, a long press allows you to activate or deactivate pairing.
A DSP chip supporting Miumax PC UI
A DSP chip is integrated in JAB2v2 and can be controlled via the programming port. After connection to a WONDOM ICP5, you can obtain the control function of the PC interface. Sure Electronics has developed a PC user interface, with which you can try out gain, high/low pass filter, noise suppressor, bass, frequency changer and many other effects.
DSP du WONDOM AA-JA32472
Many accessories available
This module comes with a 50cm power cable, and a 50cm stereo speaker with cable Molex X4 / bare wire.
Many options and accessories can enhance the JAB2. There is a cable kit , a metal mounting bracket, accumulator cradle & power manager, extension kit with USB & Jack 2.5 ports.
Use a bipolar interruptor instead a push button if you need a hardware for on/off commands.
Parts supplied with JAB
Module 18650 external accumulator battery jab
Optionnal battery module
This module can run on batteries thanks to the battery board from the same manufacturer. It is a module for 18650 battery (Li-Ion 4.2VN). When this accessory is installed, it automatically manages battery charging and powers the amplifier for a very comfortable result with a range of several hours at full power.
1.2.3 battery card connectors are 4-pin connectors to connect the battery with the amplifier card card. This also means that the battery card can load three amplifiers simultaneously.
sure-aa-ja32171-jab-2-50-module-amplific
Amplifier ChipTPA3118
Power2x 30W 8 ohms (THD + N <1%)
Frequency response20Hz - 20kHz.
THD19V @ 8Ω,10W, 1KHz
SNR19V, 10W @ 8Ω, THD+N=1%
Bluetooth compatibilityAPTX V5.0 + EDR, A2DP
Status IndicatorsLED (not included)
Protection against overcurrent and overheatingYes
Power-Supply12-24 VDC
InputsStereo analog on connector Molex43025-400 / 43025-4000
Bluetooth 5.0
Dimensions91.5 x 68.5mm
Parts supplied
2x30W Amplifier JAB 2-30 V2x1
Power cablex1
Speaker cablex1
InputNC
OutputMolex
Channel2 (Stereo)
Amplifier chipTPA3118
Power (W)30.0
3 reviews
Très simple à connecter
Je cherche à monter une enceinte à partir d'une Bose Soundlink Mini.
J'ai connecté la carte JAB2V2 aux hauts parleurs sans problème, mais la qualité du son est nettement inférieure à la Bose.
Sachant que les hauts parleurs sont de 2 x 10 Watts / 4 Ohms, est-ce un problème de puissance par rapport à la carte qui a une sortie de 2 x 30 Watts / 8 Ohms ?
Ou dois-je ajouter un module DSP ICP5 pour renforcer les basses ? Une fois les réglages effectués depuis un PC, sont-ils conservés en mémoire lorsque la carte ICP5 n'est plus reliée ?
Merci de m'éclairer.
This review has been posted for WONDOM AA-JA32472 JAB2-30 V2 Class D Stereo Amplifier Module Bluetooth 5.0 DSP 2x30W 8 Ohm
Un bon ampli
Ampli suffisamment puissant pour alimenter un boombox, aucun souffle et plutôt musical. Très simple d’ajouter un potentiomètre, interrupteur, Haut- parleurs, Leds, batterie sans soudure grâce aux nombreuses connections .
Très bon produit.
J 'ai utilise cette carte pour la création d'une enceinte 2x30 watt. elle fonctionne très bien sur alimentations secteur et batterie, pas de parasite ou bruit, Bluetooth fonction bien. Le son est très propre. J en suis très satisfait.
Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier...
