WONDOM GAB1 AA-KA32481 Amplifier Module
The WONDOM GAB1 AA-KA32481 is a compact 2.1 Class D amplifier module based on the Texas Instruments TPA3116D2 chip, capable of delivering up to 2x50 W at 4 Ohm for the stereo channels and 1x100 W at 2 Ohm for the subwoofer channel.
Reference : 22542
21,90 €tax incl.
18,25 € tax excl.
Wondom GAB1 AA-KA32481 2.1 TPA3116 Bluetooth 5.3 2x50W 4 ohm + 100W @ 2 ohm Amplifier Module
The Wondom GAB1 AA-KA32481 is a compact 2.1 Class D amplifier module based on the Texas Instruments TPA3116D2 chip, capable of delivering up to 2x50 W at 4 Ohm for the stereo channels and 1x100 W at 2 Ohm for the subwoofer channel. It offers three input modes with Bluetooth, USB Audio and analog input, allowing it to be integrated into various audio projects, including 2.1 systems, desktop setups, gaming equipment and DIY projects. The module operates with a 12 to 24 V DC power supply and features a compact 91.44 x 68.58 x 15mm format for a weight of 86.9g. It also integrates several electronic protections and can be paired with the optional Wondom ACP1H6TP external control panel to manage volume, bass, treble and crossover settings.
Les points forts du WONDOM GAB1 AA-KA32481
Wondom GAB1 AA-KA32481: Integrated DSP and Plug-and-Play PC Interface Tuning
The Wondom GAB1 integrates a DSP chip for precise sound customization. It can be connected directly to a computer using the included cable, without requiring an additional programmer or professional equipment. Its tuning interface supports a multiband equalizer, bass enhancement, DRC (Dynamic Range Compression) and crossover filtering, as well as many other audio processing functions.
WONDOM GAB1 AA-KA32481 : DSP intégré et réglages via interface PC Plug-and-Play
Wondom GAB1 AA-KA32481: Bluetooth, USB Audio and External Control
The GAB1 features connectivity combining Bluetooth, USB Audio and analog input, including an analog input via 3.5 mm jack and a 4-pin PH-2.0 mm connector. The module also features Micro-Fit connectors for the stereo and subwoofer outputs as well as for the power supply. A 12-pin PH-2.0 mm connector allows the optional ACP1H6TP control panel to be connected, providing hardware adjustment of volume, input selection, bass and treble. The panel also allows crossover adjustment, with a default frequency of 120 Hz, as well as treble adjustment of ±6 dB and bass adjustment of ±12 dB.
WONDOM GAB1 AA-KA32481 : Bluetooth, USB Audio et contrôle externe
Wondom GAB1 AA-KA32481 Overview
Aperçu du WONDOM GAB1 AA-KA32481
1Micro-fit Stereo Speaker Output
2Micro-fit Subwoofer Output
3USB Via PH-2mm
4PH-2mm External Control Port
5Stereo Line Input (3.5mm Jack and PH-2mm)
6Input Selection Button
7Micro-fit Power Supply Port
Technical Specifications
Product TypeAmplifier module
Channels2.1
AmplificationClass D
Amplification ChipTPA3116
Inputs1x USB Audio via PH-2mm
1x Stereo Line Input (3.5mm Jack / PH-2mm)
Bluetooth
Outputs1x Stereo Output via Micro-Fit
1x Subwoofer Output via Micro-Fit
Output Power2x50W 4 ohm + 100W @ 2 ohm
GainStereo Output: 27.93dB
Subwoofer Output: 32.38dB
Input SensitivityStereo Output: 775mVrms
Subwoofer Output: 775mVrms
SNRStereo Output: 112.74dB
Subwoofer Output: 96.15dB
THD+NStereo Output: 0.17%
Subwoofer Output: 0.007%
Noise LevelStereo Output: 36.06uVrms
Subwoofer Output: 287.9uVrms
Power Supply12-24V DC
Dimensions91.44 x 68.58 x 15mm
Weight86.9g ±2g
Package Contents1x Wondom GAB1 AA-KA32481
1x MicroFit cable for subwoofer output (50cm)
1x MicroFit cable for stereo output (50 cm)
1x MicroFit cable for power supply (50cm)
1x PH-4Pos to USB Type-A cable for USB input and interface control (25cm)
InputJack 3.5mm
InputPH 2.0mm
OutputMicro-fit
Channel2.1
Amplifier chipTPA3116
Power (W)100.0
Power (W)50.0
WONDOM GAB1 AA-KA32481 Amplifier Module Class D 2.1 TPA3116 Bluetooth 5.3 2x50W 4 Ohm + 100W 2 Ohm
The WONDOM GAB1 AA-KA32481 is a compact 2.1 Class D amplifier module based on the Texas Instruments TPA3116D2 chip, capable of delivering up to...
