WONDOM AA-AA11482 ACP1H6TP Audio Control Panel for JAB6 and GAB1
The WONDOM AA-AA11482 ACP1H6TP is an external audio control panel designed to be used with compatible amplifier modules from the WONDOM range, including the JAB6 and GAB1. It allows the main audio controls to be relocated to the front panel of a device or speaker, with a 3.5mm jack input, source selection, as well as dedicated potentiometers for treble, bass and volume.
Reference : 22545
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 01-12-2026.
Wondom AA-AA11482 ACP1H6TP Audio Control Panel Input/Treble/Bass for JAB6 and GAB1
The Wondom AA-AA11482 ACP1H6TP is an external audio control panel designed to be used with compatible amplifier modules from the Wondom range, including the JAB6 and GAB1. It allows the main audio controls to be relocated to the front panel of a device or speaker, with a 3.5mm jack input, source selection, as well as dedicated potentiometers for treble, bass and volume.
Its compact format and connections designed for direct integration facilitate installation in DIY audio projects, active speakers, multimedia systems or custom equipment. The panel also features a Bluetooth pairing control and an indicator showing the selected source.
Wondom AA-AA11482 ACP1H6TP: Audio Controls and Source Selection
The ACP1H6TP integrates several physical controls providing direct access to the audio functions of the associated amplifier module. Its potentiometers allow adjustment of the master volume, treble and bass, while a dedicated button provides source selection. With a GAB1, the panel can be used to manage USB, Bluetooth and analog inputs. The Bluetooth button also allows pairing to be initiated and a Bluetooth device to be disconnected by long pressing. However, the available functions depend on the DSP firmware of the connected amplifier module.
WONDOM AA-AA11482 ACP1H6TP : Commandes audio et sélection des sources
Wondom AA-AA11482 ACP1H6TP: 3.5mm Jack Input and Integration into a Wondom System
The panel features a 3.5mm jack analog input, allowing the compatible module's line input to be relocated to the front of the system. Connection to the amplifier is made via a dedicated control interface, with the appropriate cabling supplied to facilitate integration. The ACP1H6TP is particularly suited to installations where the amplifier module is placed inside an enclosure, speaker or equipment and where the controls need to remain accessible from the outside.
WONDOM AA-AA11482 ACP1H6TP : Entrée jack 3.5mm et intégration dans un système WONDOM
Wondom AA-AA11482 ACP1H6TP: Compact Design and Customizable Controls
With a format of approximately 1.5 × 6 inches, the ACP1H6TP is designed to occupy limited space while providing several physical controls. Its approximately 5mm-thick aluminum front panel, with a matte black anodized finish, integrates four potentiometers, one button and a 3.5mm jack input. Four mounting holes allow it to be installed in an enclosure. The functions associated with the potentiometers and controls can be determined by the DSP program of the compatible module, allowing customization via SigmaStudio when supported.
WONDOM AA-AA11482 ACP1H6TP : Conception compacte et commandes personnalisables
Technical Specifications
Product TypeAudio control panel
CompatibilityWondom GAP1 AA-KA32481 amplifier module
Wondom AA-JA33288 JAB6 amplifier module
ControlsVolume / Treble / Bass / Source Selection
Line Input Extension3.5mm Jack
Package Contents1x Wondom AA-AA11482 ACP1H6TP
1x PH-2mm-4POS cable for line input connection (20cm)
1x PH-2mm-12POS cable for control connection (20cm)
1x Rubber strip 6mm x 400mm x 2mm
4x M3 x 8mm socket head cap screws, 0.5mm fine thread
4x M3 x 12mm socket head cap screws, 1.2mm coarse thread
InputNC
OutputNC
ChannelN/A
ClassN/A
Amplifier chipN/A
Power (W)N/A
WONDOM AA-AA11482 ACP1H6TP Audio Control Panel Input / Treble / Bass for JAB6 and GAB1
The WONDOM AA-AA11482 ACP1H6TP is an external audio control panel designed to be used with compatible amplifier modules from the WONDOM range,...
