ATOHM DIY KIT RAFALE VR3-25 Subwoofer (Unit)
-20%
The Rafale VR3-25 kit from Atohm is an active subwoofer designed for large systems and the most extreme use cases. Its bass-reflex load carries a 500Weff generative amplification coupled to three exceptional speakers with a diameter of 23cm.
Reduced price!
Reference : 11194
1 490,00 €tax incl.
-20%
1 192,00 €tax incl.
993,34 € tax excl.
Shipping date: 17-11-2026.
Atohm Kit Rafale VR3-25
Subwoofer 500W (Unit)
Atohm Kit DIY Rafale VR3-X Subwoofer 500W (Unité)
The Rafale VR3-25 kit from Atohm is an active subwoofer designed for large systems and the most extreme use cases. Its bass-reflex load carries a 500Weff generative amplification coupled to three exceptional speakers with a diameter of 23cm. This exceptional trio has an equivalent emissive surface area to that of a 38cm and when necessary, the associated electronics allows a membrane excursion of +/-18mm ! With its many connection options, this box can be integrated without limitation into all major HiFi and Home Cinema installations. Capable of reaching absolutely amazing sound levels, even at the lowest notes, the VR3-25 is the essential ally to make you experience the most beautiful and intense sensations!
Product typeSpeaker kit
Speaker typeActive subwoofer
LoadBass Reflex 90L
Frequency response26Hz - 150Hz
Power (RMS)500W
Low level input2x RCA
High level input2x Banana plugs 4mm / Direct tightening
Cut out frequency38Hz to 200Hz or LFE switchable
Phase control0-180°
Filtering slope12dB/oct or 24dB/oct or LFE switchable
Bass/Medium SpeakerLD230TDR08 (x3)
Supply voltage115V / 230V
Consumption700Wmax
Dimensions320*830*530mm (W*H*D)
Weight49kg
The Rafale VR3-25 kit from Atohm is an active subwoofer designed for large systems and the most extreme use cases. Its bass-reflex load carries a...
