EVERSOLO C10 Master Clock
New
The Eversolo C10 is a master clock designed to provide a stable timing reference for digital Hi-Fi systems. Its SC-cut crystal OCXO oscillator aims to limit frequency variations caused by temperature and internal crystal stress, while its phase noise is specified at −115 dBc/Hz or lower at 1 Hz. This stability helps synchronized devices maintain the regularity of their digital processing.
By buying this product you get 189 loyalty points
Reference : 22697
1 890,00 €tax incl.
1 575,00 € tax excl.
EverSolo C10 SC-CUT OCXO Master Clock
EVERSOLO C10: Front view
The Eversolo C10
is a master clock designed to provide a stable timing reference for digital Hi-Fi systems. Its SC-cut crystal OCXO oscillator aims to limit frequency variations caused by temperature and internal crystal stress, while its phase noise is specified at −115dBc/Hz or lower at 1Hz. This stability helps synchronized devices maintain the regularity of their digital processing.
Eversolo C10: SC-cut oscillator and thermal control
The SC-cut geometry of the crystal helps reduce its sensitivity to thermal variations and mechanical stress, while promoting long-term stability. Precise temperature control keeps the crystal within its operating conditions, thereby limiting environment-related frequency drift. This design forms the basis of the 10MHz reference delivered by the C10.
Eversolo C10: Synchronization and RTE engine
A phase-locked loop (PLL), combined with an internal oscillator and precise feedback control, helps maintain the frequency and phase of the reference. The proprietary Reference Timing Engine (RTE) then organizes system synchronization based on this time base. The 1PPS input allows this operation to be supplemented by an external reference from a GNSS system: the C10 can thus recalibrate its long-term time base using regular synchronization pulses.
Eversolo C10: Four buffered BNC outputs
The four BNC outputs share the same clock source and cover frequencies of 10, 25 and 100MHz. Each has its own buffer circuit, designed to isolate the source from load variations and interference caused by connected devices. This distribution allows several components, such as a streamer, DAC or CD transport, to be synchronized from a common reference.
Eversolo C10: Toroidal transformer
The C10 relies on a toroidal transformer designed to limit magnetic leakage and reduce mains-related disturbances. This power supply delivers stable power to both the clock module and the control circuits, in order to maintain their operation under steady conditions. By isolating these circuits from power supply noise as much as possible, this design helps maintain the stability of the timing reference delivered by the device.
Technical specifications
Product typeAudio clock
Input1x SMB 1PPS
Outputs4x BNC
OscillatorUltra-low-noise 10MHz SC-cut OCXO
Output frequency10MHz
25MHz
100MHz
11.2896MHz
22.5792MHz
45.1584MHz
12.288MHz
24.576MHz
49.152MHz
Output waveformSquare wave
Output level1.8Vrms
Output impedance50Ω
Warm-up time5min @25°C
Default frequency offset< ±0.01ppm @ 10MHz, 25°C
Frequency stability vs. temperature< 0.003ppm, -20°C~+60°C
Aging rate< 0.002ppm
Short-term frequency stability< 9×10⁻¹³ @ τ =1 second
Phase noise≤ -115dBc/Hz @ 1Hz
≤ -129dBc/Hz @ 10Hz
≤ -139dBc/Hz @ 100Hz
≤ -145dBc/Hz @ 1000Hz
Noise floor≤ -170dBc/Hz
Supply voltage100-240V AC, 50/60Hz
ConsumptionMax: ≤ 20W
Standby: ≤ 0.8W
Dimensions365 x 310 x 88mm
Weight5.85kg
Package1x Eversolo C10
1x 50cm BNC cable
1x 1m BNC cable
1x Power cable
EVERSOLO C10 SC-CUT OCXO Master Clock
The Eversolo C10 is a master clock designed to provide a stable timing reference for digital Hi-Fi systems. Its SC-cut crystal OCXO oscillator aims...
