By buying this product you get 23 loyalty points
The Aune AR3000 is an open-back dynamic headphone featuring a 50mm driver with a titanium-coated diaphragm and an angled acoustic matrix. With an impedance of 27Ω and a sensitivity of 115dB/Vrms, it combines detailed reproduction with broad compatibility with portable sources and desktop audio systems.
Designed for music listening as well as movies and gaming, it combines an airy soundstage, a metal headband and breathable ear pads suited to extended sessions. Its 3.5mm single-ended jack and 4.4mm balanced jack cables make it easy to integrate into different setups, while its open-back design favors a wide spatial presentation.
The Aune AR3000 is an open-back headphone built around a 50 mm dynamic driver with a light, rigid titanium-coated diaphragm. This design aims to combine responsiveness and control, while the neodymium magnet and precision aluminum voice coil help track signal variations. The whole is designed to reproduce detail and timbral nuances with clarity, without losing the natural character of instruments and voices.
The driver's motor system works in conjunction with optimized airflow management to better handle large dynamic swings. This approach allows the AR3000 to deliver extended, substantial bass while retaining the impact needed for musical rhythm. It also contributes to immersion when watching movies or gaming, where intensity variations and bass effects gain more depth.
The AR3000 combines an angled baffle with ear pads that are themselves designed with an angled geometry. This acoustic matrix orients the driver relative to the ear and aims to create a deeper spatial presentation with precise source localization. The open-back design of the earcups extends this approach by letting air circulate, contributing to a more airy soundstage and a sense of space suited to both music listening and audiovisual content.
The all-metal headband features dimensions and a curvature designed to fit different head shapes. The clamping force aims to remain stable without exerting excessive pressure on the skull or cheeks, while the over-ear pads surround the ear without resting directly on it. Their memory foam and breathable covering promote comfort over the hours, whether the headphone is used for music listening, gaming or watching movies.
The AR3000's tuning was developed from measurements and listening sessions, with attention paid to the balance between bass energy, midrange accuracy and treble clarity. This tuning seeks to offer engaging listening without making long sessions fatiguing. Combined with the open-back design and the soundstage developed by the angled matrix, it allows the headphone to suit a variety of music styles and uses.
With an impedance of 27Ω and a sensitivity of 115dB/Vrms, the AR3000 can be powered by a wide range of devices, from portable sources to desktop audio systems. It comes with two 1.5m cables: an unbalanced oxygen-free copper (OFC) cable terminated with a 3.5mm jack plug, and a balanced cable with a 4.4mm jack plug. A 3.5mm to 6.35mm jack adapter completes the package for easy connection to different headphone outputs.
The all-metal headband assembly contributes to the structure's durability over time. The dark finish is enhanced by gold accents on the inner grille, whose open design remains visible from the outside. This combination of metal materials, discreet details and perforated earcups gives the headphone a understated appearance, consistent with its acoustic design.
Technical specifications
| Specifications | |
| Product type | Headphone |
| Headphone type | Open-back |
| Frequency response | 5Hz-40kHz |
| Sensitivity | 115dB |
| Impedance | 27Ω |
| Total harmonic distortion (THD) | <0.1% |
| Headphone connectors | 2x Jack 3.5mm |
| Cable length | 1.5m |
| Cable termination | 1x Jack 3.5mm 1x Jack 4.4mm |
| Detachable cable | |
| General | |
| Weight | 300g |
| Color | Black |
| Package | 1x Aune AR3000 1x Jack 3.5mm to 2x Jack 3.5mm cable 1.5m 1x Jack 4.4mm to 2x Jack 3.5mm cable 1.5m 1x Jack 3.5mm to Jack 6.35mm adapter |
| Color | Black |
| Impedance (Ω) | 27 |
| Efficiency / Sensitivity (dB) | 115.0 |
| Lowest frequency (Hz) | 5 |
| Highest frequency (Hz) | 40000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Cable termination | Jack 4.4mm |
| Headphone / Earphone connector | Jack 3.5mm |
