MOONDROP EDGE 2 Wireless Dynamic Headphone Black
New
The Moondrop Edge 2 is a closed-back wireless headphone designed for high-resolution listening, calls and gaming. Its 40mm dynamic drivers with wood composite dome are paired with adaptive active noise cancellation and a claimed battery life of up to 50 hours. Support for the LDAC and LHDC-V codecs, complemented by a low-latency wired USB connection, makes it equally suited to on-the-go listening and computer use.
Reference : 22765
129,00 €tax incl.
107,50 € tax excl.
Moondrop Edge 2 Wireless Dynamic Headphone Bluetooth 6.0 Ø40mm 20Hz-20kHz Black
MOONDROP EDGE 2: Front view
Moondrop Edge 2: 40mm dynamic drivers
The Moondrop Edge 2 is a closed-back over-ear wireless headphone based on 40mm dynamic drivers. Their wood composite dome diaphragm with flexible suspension is designed to limit distortion while controlling diaphragm excursion, in order to preserve the coherence of the reproduction. An independent acoustic cavity completes this architecture, aiming to improve sound consistency from one unit to another. Finally, the tuning is based on Moondrop's VDSF target and was measured with a B&K 5128 coupler.
MOONDROP EDGE 2: Dynamic driver
MOONDROP EDGE 2: Internal view
Moondrop Edge 2: High-resolution wireless transmission
The Edge 2 supports the LDAC and LHDC-V wireless audio protocols, which allow high-resolution streams to be transmitted from a compatible source. The design also incorporates a large antenna, intended to maintain a stable link when the headphone is used in environments where obstacles and radio interference may disrupt transmission. For wired sources, the USB-C connection allows the headphone to be used with near-zero latency, suited to gaming and content requiring precise synchronization between picture and sound.
Moondrop Edge 2: Noise cancellation
The hybrid active noise cancellation relies on an array of four microphones and adaptive DSP processing to adjust attenuation to listening conditions. Moondrop states a 24.4% improvement in processing performance over the previous model and claims noise reduction of up to 97%. When the user needs to stay aware of their surroundings or talk to someone, transparency mode reuses the microphones to pick up external sounds and reproduce them in the headphone; it can be activated using the dedicated control, with adjustable settings in the Moondrop app.
MOONDROP EDGE 2: Noise cancellation
MOONDROP EDGE 2: Beamforming noise reduction
Moondrop Edge 2: Better isolated calls in noisy environments
For calls, the Edge 2 combines two beamforming microphones with an ENC environmental noise cancellation system, assisted by an NPU chip. The processing aims to prioritize the user's voice while attenuating surrounding noise, making conversations easier in busy places. This function complements listening noise cancellation but serves a distinct purpose: clarifying the voice transmitted to the other party.
Moondrop Edge 2: Smart controls
Wear detection automatically pauses playback when the headphone is removed and resumes it when put back on, avoiding music playing needlessly. The Moondrop app also allows adjustment of the DSP graphic equalizer to tailor the sound response to the user's preferences. Profiles can be shared or downloaded from the Moondrop app, giving access to settings created by other users and making it easier to explore different sound signatures.
MOONDROP EDGE 2: In use
MOONDROP EDGE 2: 50h battery life
Moondrop Edge 2: Battery life, comfort and maintenance
The manufacturer claims up to 50 hours of battery life, extending listening sessions without frequent recharging. The contoured memory foam ear pads conform to the shape of the ears for comfort during extended wear. Wear detection and ear pads thus extend the headphone's everyday use, whether on the move, at the office or at home.
Technical specifications
Product typeWireless headphone
Headphone typeClosed-back
DriverDynamic Ø40mm
Frequency response20Hz-20kHz
Bluetooth version6.0
Bluetooth transmission protocolsA2DP / AVRCP / HFP
Supported Bluetooth codecsSBC / AAC / LDACTM / LHDC
Reception range15m without obstacles
Charging portUSB-C
Charging time1.2h
Autonomy50h
Package1x Moondrop Edge 2
1x USB-A to USB-C cable
1x Carrying case
Impedance (Ω)NC
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessYes
Cable terminationNC
Headphone / Earphone connectorUSB
Headphone / Earphone connectorWireless (Bluetooth)
MOONDROP EDGE 2 Wireless Dynamic Headphone Bluetooth 6.0 Ø40mm 20Hz-20kHz Black
The Moondrop Edge 2 is a closed-back wireless headphone designed for high-resolution listening, calls and gaming. Its 40mm dynamic drivers with...
