FIIO FT15 Planar Magnetic Headphones
New
The FiiO FT15 is a planar magnetic headphone equipped with 101mm drivers and an ultra-thin 800nm diaphragm. Combined with a proprietary magnetic circuit, this architecture aims to distribute the driving force more evenly across the diaphragm, in order to limit vibration irregularities and preserve reproduction accuracy.
Reference : 22720
499,00 €tax incl.
415,83 € tax excl.
FIIO FT15 Planar Magnetic Headphones 24 Ohm 111dB 7Hz-40kHz
FIIO FT15: Front view
The FiiO FT15 is a headphone planar magnetic equipped with 101mm drivers and an ultra-thin 800nm diaphragm. Combined with a proprietary magnetic circuit, this architecture aims to distribute the driving force more evenly across the diaphragm, in order to limit vibration irregularities and preserve reproduction accuracy.
With a sensitivity of 111dB and a weight of 425g, the FT15 can be integrated into a home Hi-Fi system as well as a sufficiently powerful portable listening setup. Its 4.4 mm balanced cable and the supplied adapters make it easy to connect to various electronics, while its lightweight design is suited to long listening sessions.
FiiO FT15: Planar magnetic headphones
The FiiO FT15 is a planar magnetic headphone equipped with 101mm drivers, designed to combine a large radiating surface with an ultra-thin 800 nm diaphragm. Its proprietary magnetic circuit distributes the flux more evenly over the coil area, in order to transmit the driving force to the diaphragm more consistently. With a sensitivity of 95 dB/mW and a stated weight of 425g, it can be used with compatible portable players and portable DAC-amplifiers, while retaining a large-diameter driver.
FIIO FT15: Diaphragm
FiiO FT15: Planar technology and 800 nm diaphragm
The FT15 diaphragm is 800nm thick, a stated reduction of 86.7% compared to the 6µm of the previous generation. This low thickness reduces the moving mass and promotes a fast response to signal variations; transients and high-frequency details can thus be reproduced accurately. FiiO also states that the diaphragm follows the signal with few residual resonances, which helps preserve clarity without causing listening fatigue.
The diaphragm features a full-surface diamond coating, applied using a specific manufacturing process. Its stiffness and mechanical strength aim to limit deformation and vibration breakup, while a vacuum heat treatment adjusts the resonance frequency of the substrate to extend the bass response. The manufacturer states a frequency response reaching up to 40kHz.
FiiO FT15: Magnetic field and distortion reduction
The heterogeneous double-sided magnet array is optimized through finite element analysis. Compared to a conventional magnetic architecture, where the field is concentrated on a narrower area, this design covers a larger area of the coil and distributes the driving force more evenly. The diaphragm thus receives a more uniform impulse across its entire surface, which aims to reduce irregular movements and harmonic distortion.
This consistency is also sought when the diaphragm moves over a greater excursion: the field maintains a more homogeneous force on the coil, in order to limit movement breakups that cause certain colorations. FiiO relies on magnetic field simulations and response measurements to develop this architecture, with the goal of coherent reproduction from low to high frequencies.
FIIO FT15: Cross-section view of a planar driver
FIIO FT15: Voice coil
FiiO FT15: Voice coil and manufacturing process
The voice coil is produced by vacuum electrodeposition using a 28nm manufacturing process. This method aims to form a uniform conductive layer and strengthen its adhesion to the diaphragm substrate, in order to maintain a stable bond during repeated vibrations. By limiting the risk of coil detachment or breakage, it helps preserve movement synchronization and driver performance over time.
FiiO FT15: Materials and lightweight design
The FT15 combines a carbon fiber headband with a specially modified plastic magnet holder, two choices that reduce mass without sacrificing structural rigidity. FiiO states a total weight of 425g, more than 50g less than the conventional planar headphones used as a reference by the manufacturer. This reduction limits the load carried during long listening sessions, despite the use of 101mm drivers.
The earcups are cut from FAS-grade American black walnut, a classification used in the wood industry to designate pieces of a high selection level. Each pair is finished and polished to preserve the natural wood grain; patterns and shades may therefore vary from one unit to another. The choice of walnut gives the structure a solid wood finish, without affecting the operation of the driver.
FIIO FT15: Carbon fiber headband
FIIO FT15: Cross-section view of the supplied cable
FiiO FT15: Balanced cable and adapters
The supplied cable uses 6N single-crystal copper treated with liquid nitrogen, with a 4.4mm balanced termination. FiiO states that this construction aims to ensure stable signal transmission and good resistance to oxidation and mechanical fatigue. A 4.4mm to 6.35mm adapter and a 4.4mm to XLR-4 balanced adapter are also included, allowing the FT15 to be connected to various sources and headphone amplifiers without changing cables.
Technical specifications
Product typeHeadphones
Headphone typeOpen-back
Frequency response7Hz-40kHz
Sensitivity95dB/mW @ 1kHz
111dB/Vrms @ 1kHz
Impedance24Ω @ 1kHz
Headphone connectors2x Jack 3.5mm
Cable length1.5m
Cable termination1x Jack 4.4mm
Detachable cable
Weight425g
Package1x FiiO FT15
1x Headphone cable Jack 4.4mm to 2x Jack 3.5mm
1x Adapter Jack 4.4mm to XLR 4-pin
1x Adapter Jack 4.4mm to 6.35mm
1x Leather headphone ear pads
1x Fabric headphone ear pads (pre-installed)
1x Storage bag
Impedance (Ω)24
Efficiency / Sensitivity (dB)111
Lowest frequency (Hz)7
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
The FiiO FT15 is a planar magnetic headphone equipped with 101mm drivers and an ultra-thin 800nm diaphragm. Combined with a proprietary magnetic...
