AUNE AR9000 Headphones
The AUNE AR9000 is a high-end open-back dynamic headphone equipped with 50mm drivers and designed to deliver spacious, natural and dynamic sound reproduction.
By buying this product you get 149 loyalty points
Reference : 22442
1 499,00 €tax incl.
1 249,17 € tax excl.
Aune AR9000 Open-Back Dynamic Headphones 50mm 43 Ohms 102dB 4Hz-50KHz
Aune AR9000
The AUNE AR9000 is a high-end open-back dynamic headphone equipped with 50mm drivers and designed to deliver spacious, natural and dynamic sound reproduction. It features an Omni-Stack Carbon Diaphragm (OSCD) made of carbon fiber, as well as a Constant-Flux magnetic circuit allowing up to 4mm of linear excursion. Its open-back design and Tilted Acoustic Matrix favor a wide and precise sound presentation, while its 43Ω impedance and 102dB SPL sensitivity at 1kHz allow use with a wide variety of sources. The AR9000 features a frequency response of 4Hz to 50kHz and total harmonic distortion below 0.03% at 1kHz. It comes with a 1.6m 8-core silver-plated OCC copper cable, supplied with interchangeable terminaison 3.5mm and 6.35mm unbalanced Jack connectors, as well as 4.4mm and balanced XLR connectors, and an AuNest carrying case.
Aune AR9000 Frequency Response Curve
Aune AR9000: Carbon Diaphragm and 4mm Excursion
The AR9000 is based on a 50mm dynamic driver using the Omni-Stack Carbon Diaphragm (OSCD), made from continuous carbon fibers arranged in precise orientations. This diaphragm combines rigidity and low mass, while a specific thermal treatment applied to different areas helps optimize its damping. The patented Constant-Flux magnetic circuit maintains a constant driving force over a linear excursion of up to 4mm, while a highly damped suspension with radial reinforcements promotes controlled diaphragm movement. The overall design allows the headphones to achieve THD below 0.03% at 1kHz.
Aune AR9000: Open-Back Design and Tilted Acoustic Matrix
The open-back design of the AUNE AR9000 allows air and acoustic energy to flow freely through the earcups thanks to breathable grilles positioned at the front and rear of the driver. The Tilted Acoustic Matrix technology angles the drivers to direct sound toward the ears, using an approach inspired by the positioning of loudspeakers. This design aims to provide a wide soundstage and precise imaging while maintaining natural sound reproduction.
Aune AR9000: 8-Core Cable and Interchangeable Connectors
The AR9000 is supplied with a 1.6m cable consisting of 8 silver-plated OCC copper cores, combined with an interchangeable termination system allowing the headphones to be adapted to different audio configurations. The 3.5mm and 6.35mm Jack plugs provide an unbalanced connection, while the 4.4mm and XLR plugs provide a balanced connection with compatible devices. The headphones also feature a metal headband with a suspended structure and breathable earpads for a high level of comfort.
Technical Specifications
Product TypeHeadphones
Headphone TypeOpen-Back
DriverDynamic Ø50mm
DiaphragmOmni-Stack Carbon (OSCD)
Nominal Impedance43 Ohms
Sensitivity102dB SPL @ 1kHz
Frequency Response4Hz-50kHz
THD<0.03% @ 1kHz
Detachable Cable
Cable Conductor MaterialSilver-Plated OCC Copper
Headphone Connectors2x 3.5mm Jack
Interchangeable Termination3.5mm Jack / 6.35mm Jack / 4.4mm Jack / 4-pin XLR
Cable Length1.6m
Weight430g
Package Contents1x Aune AR9000 Headphones
1x Detachable cable with 2x 3.5mm Jack to interchangeable termination
1x 3.5mm Jack termination
1x 6.35mm Jack termination
1x 4.4mm balanced Jack termination
1x 4-pin balanced XLR
1x AuNest Storage Case
Impedance (Ω)43
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)4
Highest frequency (Hz)50
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 4.4mm
Cable terminationXLR 4-pin
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
AUNE AR9000 Open-Back Dynamic Headphones 50mm 43 Ohm 102dB 4Hz–50kHz
The AUNE AR9000 is a high-end open-back dynamic headphone equipped with 50mm drivers and designed to deliver spacious, natural and dynamic sound...
