HIFIMAN ARYA WIFI Wireless Headphones
The HiFiMAN Arya WiFi is an open-back, over-ear planar magnetic wireless headphone featuring an all-in-one design that handles signal playback, conversion, and amplification within a single system. It utilizes an R-2R Himalaya Mini DAC paired with internal amplification, enabling the processing of high-resolution audio streams up to 32bit 768kHz PCM and DSD512 while maintaining signal integrity from the source to the driver.
By buying this product you get 159 loyalty points
Reference : 21766
1 599,00 €tax incl.
1 332,50 € tax excl.
HiFiMAN Arya WiFi Headphones Circumaural Open-Back Planar Magnetic Wireless WiFi Bluetooth 8Hz-55kHz 32bit 768kHz DSD512
Photo of the HIFIMAN Arya WiFi
Designed for both stationary and advanced portable use, it combines standalone Wi-Fi streaming, Bluetooth transmission, and a USB interface, enabling direct playback without relying on an external audio system. This approach allows it to function as a built-in network player, reducing the need for intermediaries while maintaining stable playback and precise control over the driver.
HiFiMAN Arya WiFi: Planar driver and diaphragm control
The Arya WiFi employs a planar magnetic design in which the conductors are distributed across the entire diaphragm, enabling uniform movement under the influence of the magnetic field and thereby limiting local distortions, which reduces distortion while ensuring a more stable reproduction of signal variations. This approach relies on a second-generation NEO Supernano diaphragm, whose thickness has been reduced by approximately 60%, lowering inertia and enabling better responsiveness and a cleaner high-frequency extension, while the Stealth Magnets magnetic structure limits turbulence and internal reflections, ensuring precise control of movement.
The result is a clearer sound reproduction with better separation of information; the open-back design of the headphones promotes a more natural sound distribution and a wider soundstage during complex listening sessions.
Photo showing the interior of the Arya WiFi earpiece
HiFiMAN Arya WiFi: R-2R conversion and built-in amplification
The Arya WiFi features a Himalaya Mini R-2R DAC, whose discrete resistor architecture converts the signal continuously, minimizing the approximations inherent in conventional conversions and preserving the audio signal’s structure while supporting high-resolution audio up to 32bit 768kHz PCM and DSD512. This design is further enhanced by a dual-DAC configuration that provides improved channel separation.
Beyond the conversion, the direct integration of the amplifier stage allows the headphones to be powered without the need for external components, reducing the number of interfaces and associated signal losses, which results in a more consistent sound reproduction and controlled driver performance when used as a standalone or portable device.
Image showing the different network media
HiFiMAN Arya WiFi: Built-in Wi-Fi streaming and transmission modes
The Arya WiFi features a network streaming module capable of transmitting uncompressed high-resolution audio streams, enabling direct playback over WiFi while avoiding the limitations of Bluetooth; conversion and amplification are handled internally without any intermediate steps. This architecture is based on a standalone network mode with direct configuration, allowing the headphones to connect to a local network and access content without relying on a host device, effectively transforming the system into an integrated network player and reducing the audio chain to a single active component.
Beyond Wi-Fi, this versatility extends to high-definition Bluetooth and USB audio modes, allowing you to adapt the connection type to suit the situation, while battery life lasts approximately 6.5 to 7.5 hours over Wi-Fi and up to 23 hours over Bluetooth, enabling you to switch between network streaming, wireless, and wired connections as needed.
Diagram of the Arya WiFi headset and its various buttons
Product typeHeadphones
Headphone typeOpen-back circumaural
TransducersPlanar magnetic
Frequency response8Hz-55kHz
DACR-2R HIMALAYA Mini
Operating modesWiFi
USB Audio
Bluetooth
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Charging portUSB-C
Battery life7.5h WiFi Mode
23h Bluetooth Mode
+30 days standby
Charging time3-4h
THD+NDAC : 0.0055% @ -9dB, 1kHz
DAC + AMP : 0.009% @ 32 Ohm, 1kHz
Channel separation105dB @ 1kHz
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Weight452g
Package1x HiFiMAN Arya WiFi
1x Pair of ear pads (mounted on headphone)
1x USB-C Cable
Impedance (Ω)NC
Lowest frequency (Hz)8
Highest frequency (Hz)55000
WirelessYes
Cable terminationUSB-C
Headphone / Earphone connectorUSB
Headphone / Earphone connectorWireless (Bluetooth)
HIFIMAN ARYA WIFI Headphones Circumaural Open-Back Planar Magnetic Wireless WiFi Bluetooth 8Hz-55kHz 32bit 768kHz DSD512
The HiFiMAN Arya WiFi is an open-back, over-ear planar magnetic wireless headphone featuring an all-in-one design that handles signal playback,...
