By buying this product you get 196 loyalty points
The HIFIMAN HE6 Remastered is an open-back circumaural Hi-Fi headphone with planar magnetic drivers. This version uses the historic HE6 planar driver, while evolving its structure with a new lightweight alloy headband designed to improve ergonomics. It covers a frequency response from 8Hz to 65kHz, with an impedance of 50Ω, a sensitivity of 83.5dB and a headphone connection via 3.5mm jack.
Intended for sedentary listening, it requires a headphone amplifier capable of delivering a level of power suited to its sensitivity. Its open-back design and planar driver favor a detailed reproduction, fast transients and an airy soundstage.
The HE6 Remastered uses a planar magnetic driver derived from the architecture of the original HE6. Its ultra-thin diaphragm integrates fine conductive traces, which reduces the moving mass and allows a fast response to signal variations, while limiting distortion. The open-back design favors an airy soundstage, while the frequency response extends from 8Hz to 65kHz. With an impedance of 50Ω and a sensitivity of 83.5dB, the headphone requires an amplifier capable of delivering a suitable level of power.
The HE6 Remastered adopts an open-back circumaural construction, with rear cups protected by grilles. Its lightweight alloy headband integrates swiveling hinges, while the enveloping ear pads are replaceable. The headphone connection is made via a 3.5mm jack. The whole design is dedicated to sedentary listening, with an open-back design and an interface compatible with a suitable headphone amplifier.
"As Hifiman’s first ultra-high-end headphone, the HE6 remains, long after its withdrawal from the catalogue, the Chinese brand’s most popular product. Such is its popularity that, in addition to the launch of the HE600 – a sort of recent (and highly successful) ‘half-brother’ model that adopts some of its design cues – the manufacturer has finally decided to revive this headphone with an updated version. The HE6 Remastered retains part of its predecessor’s design, as well as a ‘recreated’ version of the original driver, whilst modernising the shape."
Technical specifications
| Specifications | |
| Product type | Headphone |
| Headphone type | Open-back circumaural Planar magnetic |
| Impedance | 50Ω |
| Sensitivity | 83.5dB |
| Frequency response | 8Hz-65kHz |
| Cable termination | 3.5mm jack |
| General | |
| Color | Black |
| Weight | 522g |
| Package | 1x HiFiMan HE6 Remastered 1x 4 pins XLR cable3m 1x Jack 6.35mm cable 3m |
| Color | Black |
| Impedance (Ω) | 50 |
| Efficiency / Sensitivity (dB) | 83.5 |
| Lowest frequency (Hz) | 8 |
| Highest frequency (Hz) | 65000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | Jack 3.5mm |
