MEZE EMPYREAN II Headphones
The Meze Empyrean II is an open-back headphone featuring an isodynamic planar magnetic driver, designed for wide-band reproduction based on a dual-emission-zone architecture. It delivers an extended frequency response from 8Hz to 110kHz, utilising signal distribution across different sections of the diaphragm to limit phase interactions and stabilise transient response, resulting in a consistent and controlled reproduction across the entire spectrum.
By buying this product you get 299 loyalty points
Reference : 22021
2 990,00 €tax incl.
2 491,67 € tax excl.
Meze Empyrean II Open-Back Isodynamic Planar Magnetic Headphones 32 Ohm 91dB 8Hz–110kHz
Meze Empyrean II : Vue de face
Designed for high-fidelity listening at home, it combines an open acoustic design with customisable sound via its interchangeable pads, allowing you to adjust the bass response or the soundstage depending on your needs.
Meze Empyrean II: Isodynamic planar magnetic driver
The Meze Empyrean II features a dual-emission-zone isodynamic planar magnetic driver, which distributes the frequency response across different sections of the diaphragm to minimise phase interactions, thereby stabilising the response across the entire spectrum. This design is underpinned by an optimised magnetic circuit and an extended active surface area, ensuring uniform movement of the diaphragm, thereby reducing distortion whilst preserving dynamic micro-variations.
Meze Empyrean II : Diaphragm
Meze Empyrean II : Components on a table
Meze Empyrean II: Exquisitely crafted sound
The open design facilitates the dissipation of the rear wave, which reduces internal reflections and improves soundstage perception, whilst the internal geometry and positioning of the transducer align the sound with the ear to maintain temporal coherence. This approach is extended through the use of interchangeable pads (Duo / Alcantara), whose structure and porosity modulate the acoustic load: the Duo pads enhance coupling with the ear, thereby increasing the density of the bass range, whilst the Alcantara pads introduce more gradual absorption, allowing for a more airy reproduction and a perceived wider soundstage. This controlled variability allows the sound to be adjusted without altering the overall balance of the driver.
Meze Empyrean II: Remarkably ergonomic
The rigid ABS frame, reinforced with fibreglass, minimises unwanted vibrations, which stabilises the driver’s performance and ensures clear sound reproduction whilst keeping the weight to a minimum. This design is complemented by a self-adjusting suspension system that distributes pressure evenly across the headband, ensuring a truly comfortable listening experience, even during long sessions.
Meze Empyrean II : Being manipulated
Product typeHeadphone
Headphone typeOpen-Back
DriverIsodynamic Planar Magnetic
Frequency response8Hz–110kHz
Impedance32Ω
Sensitivity90dB
Maximum sound pressure level>130dB
Total harmonic distortion (THD)<0.05%
Frame materialABS infusé de fibre de verre
Headphone connectors4-pin mini XLR
Cable terminationJack 6.35mm
Detachable cable
Adjustable headband
Detachable pads
Weight449g
Package1x Meze Empyrean II
1x 6.35mm jack to 4-pin dual mini XLR cable
Impedance (Ω)32
Efficiency / Sensitivity (dB)91.0
Lowest frequency (Hz)8
Highest frequency (Hz)110000
WirelessNo
Headphone / Earphone connectorMini XLR 4 Pins
MEZE EMPYREAN II Headphones Open-Back Isodynamic Planar Magnetic 32 Ohm 91dB 8Hz–110kHz
The Meze Empyrean II is an open-back headphone featuring an isodynamic planar magnetic driver, designed for wide-band reproduction based on a...
