MOONDROP OLD FASHIONED Dynamic Headphones
The Moondrop Old Fashioned is a dynamic headphone featuring a 40mm driver. It adopts the iconic design of 1990s headphones with a telescopic headband for comfortable fit and adjustability.
Reference : 21549
29,57 €tax incl.
24,64 € tax excl.
Shipping date: 01-12-2026.
Moondrop Old Fashioned Open-Back Dynamic Headphones 32 ohm 109dB 20Hz-20kHz
Photo of the MOONDROP OLD FASHIONED
The Moondrop Old Fashioned is a dynamic headphone featuring a 40mm driver. It adopts the iconic design of 1990s headphones with a telescopic headband for comfortable fit and adjustability. Its 32-ohm impedance and 109dB sensitivity make it easy to drive. It comes with a detachable cable using CIEM 0.78mm connectors and a 3.5mm jack termination with inline volume control for excellent versatility. This headphone is perfectly suited for everyday use.
Technical Specifications
Product typeHeadphones
DriverDynamic Ø40mm
DiaphragmThree-layer rigid-flex composite
Impedance32Ω ±15% (@ 1kHz)
Sensitivity109dB/Vrms (@ 1kHz)
Frequency response20Hz-32kHz (IEC61094, Free Field)
Effective frequency response20Hz-20kHz (IEC60318-4, -3dB)
THD≤ 0.2% (@ 94dB, 1kHz)
Detachable cable
Headphone connectorsCIEM 0.78mm
Termination3.5mm jack
Package contents1x Moondrop Old Fashioned
1x CIEM 0.78mm to 3.5mm jack cable
Impedance (Ω)32
Efficiency / Sensitivity (dB)109
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
No brainer
If you need this type of phones, this is a no-brainer. Its feather lite, sound really good, just add bass below 100Hz. I use them to rest my ears from in-ears, and in hot weather instead of full on-ears, if I don't listen clinically.
The thing that you can replace ear foam and cable is great, its just these are so cheap that it maybe a gimmick.
This review has been posted for MOONDROP OLD FASHIONED Dynamic Headphones 32 Ohms 109dB 20Hz-20kHz
The Moondrop Old Fashioned is a dynamic headphone featuring a 40mm driver. It adopts the iconic design of 1990s headphones with a telescopic...
