SIVGA PENG Closed-back Dynamic Headphones
New
The SIVGA PENG headphones are closed-back dynamic headphones that combine technology and craftsmanship. They feature 50mm diameter transducers with dynamic diaphragms for high-fidelity sound. Their clear and precise sound reproduction is also immersive thanks to their circumaural design. Their high-end audiophile components are complemented by craftsmanship in their design.
Reference : 21097
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 09-09-2025.
SIVGA PENG Closed-back Dynamic Headphones Ø50mm 340Ω 102dB 20Hz-40kHz Zebrano Wood
SIVGA PENG picture
The SIVGA PENG headphones are closed-back dynamic headphones that combine technology and craftsmanship. They feature 50mm diameter transducers with dynamic diaphragms for high-fidelity sound. Their clear and precise sound reproduction is also immersive thanks to their circumaural design. Their high-end audiophile components are complemented by craftsmanship in their design. The ear cups are machined from solid African Zebrano wood, while the headband is made from lambskin leather for maximum user comfort. Added to this are ergonomic ear pads that provide the necessary comfort during long listening sessions. It is also worth noting that the headphones are fully detachable, allowing each component to be replaced individually for a high level of durability and repairability. In terms of sound quality, the SIVGA PENG is ideal for discerning music lovers thanks to its powerful and rich reproduction.
SIVGA PENG headphone picture
SIVGA PENG: a 50mm transducer
The SIVGA PENG headphones deliver music reproduction with deep, immersive bass and subtle treble thanks to their 50mm diameter transducers, which cover a wide frequency range in a balanced way. The LCP (Liquid Crystal Polymer) diaphragm material also offers numerous benefits. The rigidity and lightness of LCP provide high responsiveness while reducing unwanted vibrations, while a sapphire composite plating ensures refined detail and optimized clarity.
SIVGA PENG structure
SIVGA PENG: optimal comfort
All of the materials and ergonomics of the SIVGA PENG headphones have been designed to offer durability and comfort during long listening sessions. Lightweight and sturdy, the stainless steel headband ensures excellent support, while the lambskin leather headband adapts to a wide range of head shapes. At the junction between the headband and the ear cups, there is a 180° swivel mechanism for optimal adaptation to the user's head shape. The ear pads naturally fit the contours of the ears for a circumaural fit that provides a very good level of passive isolation.
SIVGA PENG materials
SIVGA PENG: handcrafted using high-end materials
The SIVGA PENG's solid African Zebrano wood shell immediately catches the eye, giving it a highly elegant appearance. Handcrafting this noble material offers a unique finish combined with all the high-end components of the headphones. Each of these components is also easily removable and replaceable to ensure the longevity of this audiophile gem.
Focus on the wooden shell of the SIVGA PENG
SIVGA PENG: audiophile accessories
The SIVGA PENG comes with a cable featuring 6N OCC copper conductors for flawless signal transmission. This cable has two 3.5mm jack connectors for headphones and a balanced 4.4mm jack termination for compatibility with high-end HiFi devices. Two adapters are also included, a 3.5mm jack adapter and a 6.35mm jack adapter, to ensure universal compatibility. For storage, a stylish hard case allows you to transport your headphones while protecting them.
SIVGA PENG accessories
Product typeHeadphones
Headphone typeCircum-aural
Headphone structureClosed-back
Transducers typeDynamic
Speaker diameterØ50mm
Impedance340 ohms
Sensitivity102dB ± 3dB
Frequency response20Hz – 40kHz
Diaphragm materialLCP polymer (Liquid Crystal Polymer)
Diaphragm platingSapphire Composite
Shell materialsAfrican Zebrano wood
Detachable cable
Headphone connectors2x 3.5mm jack
Cable terminaisonBalanced 4.4mm jack
Conductors cable materialOCC 6N copper
Weight341g
Package1x SIVGA PENG headphones
1x Detachable cable 2x 3.5mm jack to 4.4mm balanced jack termination
1x 4.4mm jack to 3.5mm jack adapter
1x 4.4mm jack to 6.35mm jack adapter
1x Hard storage case for headphones
1x Pouch for cable and adapter
ColorWood
Impedance (Ω)340
Efficiency / Sensitivity (dB)102.0
Lowest frequency (Hz)20
Highest frequency (Hz)40000
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
The SIVGA PENG headphones are closed-back dynamic headphones that combine technology and craftsmanship. They feature 50mm diameter transducers with...
