THIEAUDIO CYPHER Headphones
The THIEAUDIO Cypher is an open-back headphone featuring a 50mm dynamic driver, designed for wide and airy reproduction. It relies on a high flux density magnetic circuit in order to better control the diaphragm, allowing it to maintain a stable response across the entire 20Hz-20kHz spectrum, while promoting good separation between frequency ranges.
Reference : 22061
469,00 €tax incl.
390,83 € tax excl.
Shipping date: 13-11-2026.
Thieaudio Cypher Open-Back Dynamic Headphones 32 Ohms 96dB 20Hz-20kHz
Thumbnail of the THIEAUDIO Cypher
The Thieaudio Cypher is an open-back headphone featuring a 50mm dynamic driver, designed for wide and airy reproduction. It relies on a high flux density magnetic circuit in order to better control the diaphragm, allowing it to maintain a stable response across the entire 20Hz-20kHz spectrum, while promoting good separation between frequency ranges.
It combines a 32Ω impedance and a sensitivity of approximately 96dB, enabling use with a variety of sources while maintaining improved control when paired with dedicated amplification. This approach extends with a dual 3.5mm jack detachable connection, facilitating integration into different audio chains, while its mechanical design with a suspended headband ensures stable positioning during extended listening sessions.
Thieaudio Cypher: Driver and reproduction
The Cypher is based on a 50mm dynamic driver incorporating a multi-magnet N45 magnetic circuit with 20 cores, whose stabilized flux density improves diaphragm control, allowing distortion to be reduced while maintaining good transient response. This mechanical control extends through an open-back design that reduces internal resonances, resulting in a wider soundstage and improved layer readability.
The 20Hz to 20kHz frequency response covers the entire audible spectrum, while maintaining present bass without overload, the overall balance favoring clarity rather than pressure.
Photo of the THIEAUDIO Cypher driver
Thieaudio Cypher: Driving conditions and interface
With a 32Ω impedance and a sensitivity of approximately 96dB, the headphones remain easy to drive while gaining in stability when paired with dedicated amplification. This compatibility allows use with both mobile sources and DACs or headphone amplifiers.
The dual 3.5mm jack connection on the earcups enables the use of detachable cables, allowing easy adaptation to balanced or single-ended configurations depending on the setup.
Thieaudio Cypher: Construction and usage stability
The structure combines aluminum, stainless steel and carbon fiber, reducing unwanted vibrations while ensuring overall rigidity. This design extends with a weight of approximately 411g, distributed through a suspended headband and memory foam earpads, allowing stable positioning without creating pressure points. This mechanical stability directly contributes to maintaining consistent acoustic coupling, especially during extended listening sessions.
Photo of the THIEAUDIO Cypher with ear pad removed
Technical specifications
Product typeHeadphones
Headphone typeOpen-back
DriverDynamic
Frequency response20Hz to 20kHz
Nominal impedance32Ω
Sensitivity96dB @ 1kHz/1Vrms
Detachable cable
Headphone connectors2x 3.5mm jack
Cable length1.5m
Cable termination connectorJack 3.5mm
Dimensions225 x 190 x 142.5mm
Weight411g
Package contents1x Thieaudio Cypher
1x Dual 3.5mm jack to 3.5mm jack cable
1x 3.5mm jack to 6.35mm jack adapter
Impedance (Ω)32
Efficiency / Sensitivity (dB)96.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
THIEAUDIO CYPHER Open-Back Dynamic Headphones 32 Ohms 96dB 20Hz-20kHz
The THIEAUDIO Cypher is an open-back headphone featuring a 50mm dynamic driver, designed for wide and airy reproduction. It relies on a high flux...
