LUNDAHL LL1684 Audio Transformer (Unit)
The Lundahl LL1684 is a high-quality, general-purpose amorphous-core transformer that can be used for microphone or line input, line output, and galvanic isolation.
Reference : 22241
143,67 €tax incl.
119,72 € tax excl.
Shipping date: 17-11-2026.
LUNDAHL LL1684
The Lundahl LL1684 is a high-performance general-purpose amorphous core transformer that can be used for microphone or line inputs, line outputs, and galvanic isolation. The windings are arranged to provide perfect symmetry when the transformer is used in phase-splitting input applications. The dual-coil structure also significantly improves immunity to external magnetic fields generated by power supplies and motors, for example. The primary and secondary windings are separated by electrostatic shields. The transformer is housed in a mu-metal enclosure.
LUNDAHL LL1684
Technical Specifications
Product typeAudio transformer
Turns ratio1 + 1 : 1 + 1
DC resistance of each primary winding41Ω
DC resistance of each secondary winding41Ω
Distortion (primary windings connected in series, 150Ω source impedance)+23dBU 0.1% at 50Hz +25dBU <1% at 50Hz
Distortion (primary windings connected in parallel, 150Ω source impedance)+16dBU 0.1% at 50Hz +19dBU <1% at 50Hz
Self-resonant frequency>250kHz
Frequency response (150Ω source, 10kΩ load, series connection)10Hz-100kHz ±1.0dB
Phase response (deviation from linear phase)20Hz–20kHz, ±0.5°
Recommended load for optimum square-wave response10kΩ // 1kΩ + 3nF
Insulation between windings / between windings and shield3kV / 1.5kV
Dimensions42 x 28 x 22mm
Pin spacing5.08mm (0.2")
Row spacing30.5mm (1.2")
Recommended PCB hole diameter1.5mm
Weight81g
Package contents1x LUNDAHL LL1684
The Lundahl LL1684 is a high-quality, general-purpose amorphous-core transformer that can be used for microphone or line input, line output, and...
