LUNDAHL LL1531 Audio Transformer (Unit)
The Lundahl LL1531 is a compact, high-impedance line input transformer designed for bridging input applications.
Reference : 22243
69,57 €tax incl.
57,97 € tax excl.
Shipping date: 17-11-2026.
LUNDAHL LL1531
The Lundahl LL1531 is a compact, high-impedance line input transformer designed for bridging input applications. It consists of two coils, each featuring one primary winding and one secondary winding separated by an electrostatic shield. The two secondary windings are internally connected in series. The core is made from high-permeability mu-metal laminations, while the transformer is magnetically shielded by a mu-metal enclosure.
As a high-impedance transformer, the LL1531 is normally intended to be used with the primary windings connected in series.
LUNDAHL LL1531
Technical Specifications
Product typeAudio transformer
Turns ratio1 + 1 : 2
DC resistance of each primary winding500Ω
DC resistance of the secondary winding1.3kΩ
Distortion (primary windings connected in series, 600Ω source impedance)Primary level +10dBU, 50Hz: 0.2%
Primary level +20dBU, 50Hz: 1%
Self-resonant frequency> 80kHz
Optimum termination for best square-wave response (600Ω source impedance)8kΩ in series with 1.2nF
Frequency response (source and load as above)10Hz-25kHz ± 0.3dB
Insulation between windings / between windings and shield3kV / 1.5kV
Dimensions28 x 17 x 15mm
Pin spacing3.81mm (0.15")
Row spacing20.32mm (0.8")
Weight25g
Recommended PCB hole diameter1.5mm
Package contents1x LUNDAHL LL1531
