By buying this product you get 459 loyalty points
The miniDSP Tide16 is an A/V home theater processor designed to handle immersive Dolby Atmos and DTS:X formats, while providing decoding and processing of configurations up to 16 channels. Its quad-core ARM processor clocked at 1.8 GHz combines processing power, low consumption and limited thermal dissipation, while its fully balanced XLR outputs maintain a low level of noise and distortion.
Intended for home theater installations, professional studios and audiophile systems combining cinema and stereo listening, it associates HDMI, eARC, USB, Bluetooth LDAC and aptX HD inputs, XLR/RCA analog links and S/PDIF digital inputs. This architecture is extended by the integration of the Dirac Live, Bass Control and Active Room Treatment suites, as well as by a mixing matrix and advanced bass management, allowing precise adaptation of multiple subwoofers, active speakers or multichannel configurations from a single platform.
"The Tide16 outperformed some 67 other products and leaves the best of them far behind! Its distortion is infinitesimal. Its performance is therefore limited only by noise, which remains quite respectable at more than 19 bits. There are indeed a few low-level conversion errors, which should nevertheless not result in audible artifacts and which, in any case, are much better than those of many audiovisual products.
And all of this is housed in a compact enclosure and offered at an incredibly low price. I often recommend that people buy a tuner amplifier and use it as a processor, because multichannel devices are very expensive. That is not the case here."
Technical specifications
| Specifications | |
| Product type | Audio / Video Processor Home Theater Preamplifier |
| Channels | 16 |
| Inputs | 1x RJ45 1x USB-B 2x USB-A 2x Coaxial 2x Toslink Optical 1x RCA stereo 1x XLR stereo 3x HDMI Wifi Bluetooth |
| Outputs | 16x XLR 1x HDMI EARC / ARC |
| Other connectors | 1x Trigger Input 2x Trigger Output |
| Signal-to-noise ratio (SNR) | 125dB |
| Frequency response | 20Hz–20kHz (±0.05dB) |
| Processor | Quad Core A53 ARM |
| HDCP version | 2.3 |
| eARC support | |
| DAC | ES9842QPRO |
| Input impedance | 100kΩ |
| Output impedance | 200Ω |
| Channel separation | -120dB |
| Supported formats | Dolby Atmos, Dolby Atmos Height Virtualization, Dolby Atmos Music, Dolby TrueHD, DTS HD Master, DTS:X, DTS Neural:X, DTS Virtual:X |
| Total harmonic distortion more noise (THD+N) | -118dB |
| Input level | 4Vrms |
| Output level | 4Vrms |
| Bluetooth codecs | LDAC / aptX HD / aptX / AAC / SBC |
| General | |
| Supply voltage | 90~240V AC, 50/60Hz |
| Dimensions | 433 x 255 x 90mm |
| Color | Black |
| Package | 1x miniDSP Tide16 1x IR Flasher 1x Remote control 1x Power cable |
