MOGAMI 2552 Balanced micro Superflexible Shielded cable 2x0.14mm² Ø5mm
Reference : 9837
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 23-06-2026.
The MOGAMI 2552 cable is designed to be tough and flexible at the same time.
Thus, it is particularly suitable for stage and studio.
Features:
  • Conductor Copper 2x 0.14mm²
  • Insulation Low-noise polyethylene XLPE
  • Double shielding: enclosed Spiral copper
  • Flexible PVC sheath
  • External Diameter: 5mm
  • This conductor with the cut is delivered to the linear meter, one ordered unit is equal to one meter delivered (the lengths are delivered in one piece)
SPECIFICATIONS
Configurationmogami cable diagram w2552mogami cable diagram w2447mogami cable diagram w2792
W2552 W2582 W2447 W2435 W2792
No. of Conductor 2
Conductor Details 12 / 0.12 A <T250D * 3>
Size (mm²) 0.135mm² (# 26 AWG)
Insulation Ov. Dia. (Mm) 1.5Ø (0.059 ")
Material LNXLPE (Low Noise Cross-Linked Polyethylene)
Colors Red / Clear
Served Shield Approx. 67 / 0.12A Approx. 36 / 0.12A Approx. 95 / 0.12A
Jacket Ov.Dia. (Mm) 5.0Ø (0.197 ") 6.0 (0.236 ") 5.0Ø (0.197 ") 6.0 (0.236 ") 6.0 (0.236 ")
Material Flexible PVC
Colors Black Black / Red / Yellow / Green / Blue / Gray Black Black Black / Red / Yellow / Green / Blue / Gray
Roll Sizes 50m (164 Ft)
100m (328Ft)
200m (656Ft)
50m (164 Ft)
100m (328Ft)
200m (656Ft)
100m (328Ft)
200m (656Ft)
100m (328Ft)
200m (656Ft)
50m (164 Ft)
100m (328Ft)
200m (656Ft)
Weight per 200m Roll 7.5kg 9kg 7.7kg 9kg 8.8kg
ELECTRICAL & MECHANICAL CHARACTERISTICS
Part No. W2552W2582W2447W2435W2792
DC Resistance at 20 ° C Inner Cond.0.14W / m (0.043W / Ft)
Shield0.003W / m (0.009W / Ft)0.002W / m (0.006W / Ft)
Capacitance at 1kHz, 20 ° C
(Partial C. Value)
See below figure *
K090pF / m (27pF / Ft)123pF / m (37.5pF / Ft)127pF / m (38.7pF / Ft)
K110pF / m (3pf / Ft)-
Inductance between conductors at 1kHz. 20 ° C 0.8μH / m (0.24μH / Ft)
Electrostatic Noise **50mV Max.50mV Max.0.5mV Max.
Electromagnetic Noise **0.15mV Max.
Microphonics at 50KW Load **30mV Max.30mV Max.30mV Max.30mV Max.1mV Max.
Voltage BreakdownMust withstand at DC 500V / 15sec.
Insulation Resistance100000 MW × m Min. at DC 125V, 20 ° C
Flex Life **11,000 cycles13,800 cycles14,000 cycles24,000 cycles22,000 cycles
Tensile Strength421N441N451N480N490N
EmigrationNon-emigrant to ABS
Applicable Temperature-20 ° C. + 70 ° C. (-4 ° F. + 158 ° F)
Diameter (mm)5.0
Length (m)Sold by length
Number of conductors2
Insulation materialXLPE / XLCPE
ShieldingYes
Section (mm²)0.14
Ground / ShieldingYes
2 reviews
Bon câble.
Un peu délicat à mettre en oeuvre. Ce câble est très souple et a de bonnes performances électriques - résistance, capacité.
0 l'écoute pour un câble phono de 75 cm, assez brillant, précis, graves assez secs, nets, mais peut-être un peu en retraits.
Après, juger un câble c'est un peut difficile.
Si vous cherchez de la précision, je vous le conseil.
This review has been posted for MOGAMI 2552 Balanced micro Superflexible Shielded cable 2x0.14mm² Ø5mm
Adecuado
Buena calidad y flexibilidad
