MOGAMI 2930 Interconnect Cable
The Mogami 2930 is a professional 2 channels interconnect cable, renowned for its exceptional electrical and mechanical performance. It is widely used in professional audio studios and installations for its sound transparency, low noise, and remarkable flexibility. This cable is ideal for applications requiring stable and reliable signal transmission.
Reference : 21314
9,95 €tax incl.
8,29 € tax excl.
Shipping date: 17-11-2026.
Cable sold by the meter
Mogami 2930 Interconnect Cable 2 Channels Copper 2x0.15mm² Ø7.5mm
Mogami 2930
Mogami 2930: cutting diagram
Mogami 2930: Transparency and low noise
The Mogami 2930 is designed to provide optimal sound transparency, ensuring faithful reproduction of the audio signal. Thanks to the use of high-quality materials, such as XLPE cross-linked polyethylene and an additional ground conductor, it minimizes interference and noise, ensuring impeccable audio quality.
Mogami 2930: Flexibility and robustness
This cable stands out for its flexibility and mechanical strength, making it easy to handle and install, even in demanding environments. Its compact structure and effective shielding make it a preferred choice for audio professionals.
Product typeInterconnect cable
Conductors number2
Conductors section2x 0.15mm² (26AWG)
Drain wireOui
Drain wire section0.18mm² (25AWG)
Conductors materialCopper
ShieldingBraided sheath
Conductors sheathXLPE
Cover sleevePVC
Outer diameterØ7.5mm
DC resistance @ 20°CCore (pair): 0.058Ω/m
Shielding: 0.031Ω/m
Capacity @ 1kHz, 20°CBetween a conductor and shielding: 120pF/m
Between two drivers: 12pF/m
Inductance0.6µH/m
Electrostatic noise2.5mV Max
Electromagnetic noise @ 10kHz0.1mV Max
Microphonic noise50mV loaded at 50kΩ
Break currentDC 500V for 15 seconds
Insulation resistance105MΩ Min DC 125V
Mechanical strength of a pair at 26°C274N
Chemical stability over timePVC does not harden
Operating temperature-20°C / +70°C
StandardUL 13 CL2X 60°C - UL 20002 AWM 30V 60°C VW-1
LengthSold by the meter
Diameter (mm)7.5
Number of conductors2
Insulation materialXLPE / XLCPE
ShieldingYes
Section (mm²)0.15
Ground / ShieldingYes
MOGAMI 2930 Interconnect Cable 2 Channels Copper 2x0.15mm² Ø7.5mm
The Mogami 2930 is a professional 2 channels interconnect cable, renowned for its exceptional electrical and mechanical performance. It is widely...
