RAMM AUDIO ELITE 8 Interconnect Cable OCC Copper Triple Shielding Ø9,2mm
The Ramm Audio Elite8 is designed to provide the best possible analog connection to preserve the integrity of the transmitted signal. The result is a very low level of distortion and noise for a very transparent reproduction.
Reference : 15397
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 10-06-2026.
câble au mètre
Ramm Audio Elite8
Ramm Audio Elite8 Câble de modulation Cuivre OCC Triple Blindage Ø9.2mm
To achieve this result, the Elite8 incorporates geometrically organized OCC copper conductors with triple shielding and cotton filling. Each conductor is cryogenically treated to further improve transmission quality. It also uses the NBU (Noise Bypass Unit) technology with the use of a floating ground, which consists in separating the shield ground from the signal ground. The shield ground, connected only on one side, works like a Faraday cage, protecting the conductors from interference. A beautiful gold and black Nylon sheath finally dresses the cable, giving it excellent mechanical resistance and a beautiful design. This model is ideal for symmetrical connections.
Manufacturer's assembly instructions for wiring XLR connectors:
- The connection is made directly Pin to Pin for each of the 3 cores. The earth wire is optional, but can be connected to the body of the source connector.
Manufacturer's assembly instructions for wiring RCA connectors:
- Combine 2 cores for the (-) signal, and 1 core for the (+) signal. The earth wire is connected to the source connector.
Ramm Audio Elite 8 : Composition diagram
Ramm Audio cables comparison
Elite 8
Elite-XTRA
Elite 72 (E72)
Mozart2
Cable geometry
Air-Inside© geometry with multi-layer shielding for excellent transparency and resolution, with less distortion and noise
Conductors
Single-core OCC copper
Number of conductors
3 individually shielded conductors
2 individually shielded conductors
Conductor composition
3 wires of 0.65mm, 0.60mm and 0.55mm individually wrapped in silk thread
2 x 0.5mm PP-insulated wires
3 x 0.5mm bare wires
1 x 0.6mm bare wire
Drain wire
3 x 0.6mm OFC monocrystalline copper strands
3 x 0.5mm OFC monocrystalline copper strands
1 x 0.65mm OFC monocrystalline copper wire
Dielectric
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
Conductors shielded by copper foil
Capacitance (pF/m)
140
203.51
203
155
Resistance (Ω/m)
0.024
0.03274
0.033
0.028
Inductance (µH/m)
1.4
1.31394
1.32
1.25
Characteristics
Natural, pure and transparent sound with smooth musicality and exceptional sound image. Quiet, excellent noise and interference rejection
Clean, natural signal transfer for dynamic performance with better-defined deep bass and smoother highs
Musical, transparent and smooth with excellent sound image
Sound image with highlighted voices. Natural sound with low distortion and noise
Connectors
Balanced connection, usually XLR
Single-ended connectors, usually RCA
Outer diameter
9.2mm
9.2mm
8.2mm
9mm
Product typeInterconnect cable
ConductorsOCC Copper
Cable diameterØ9.2mm
Triple shieldingAluminum-Mylar + PP
External sheathPVC
Cover sleeveBraided Nylon
ColorBlanc and gold
QuantitySold by the meter
Diameter (mm)9.2
Number of conductors3
Insulation materialPolypropylene (PP)
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
11 reviews
Mesure au pied a coulisse du diametre 8mm
Ceci exclu le filet dore qui a mon avis et en trop . De plus je trouve la gaine noire élégante avec son aspect carbone . Flexibilité pauvre et montage un peu laborieux .J' ai toujours aime le son du cuivre pur avec un blindage minimum . Apres une heure d' écoute ce câble est pour son prix au top . SUPER
This review has been posted for RAMM AUDIO ELITE 8 Interconnect Cable OCC Copper Triple Shielding Ø9,2mm
Excellent
Pour le prix, ce câble rivalise avec d'autres plus cher, plus ou moins souple. Plus qu'à monter de bonnes fiches.
Super câble
Je l'ai acheté sur les avis et je comprends pourquoi tous sont unanimes sur ce câble.
Il est déjà de très bonne qualité, quoi que un peu bling bling avec sa gaine dorée. Il n'est pas simple à dénuder, il faut de la patience car chaque conducteurs est composé de 3 brins de cuivre qui sont eux-même blindés et enroulés dans du coton. Pour le coup, la protection est poussée à l'extrême.
Un petit détail que j'ai vraiment apprécié; c'est quand on prépare des câbles de modulation en symétrique, le point chaud et la masse sont inversés entre mâle/femelle ; Ici les connecteurs sont placés directement pour accueillir le mâle et la femelle, pas besoin de tortiller le conducteur pour pouvoir souder, c'est du génie, le soucis du détail.
Quant au son, il limpide, neutre, précis, ce que je recherchais avec beaucoup de dynamique, ce câble remplace un câble pur argent, mais je l'ai connecté avec des VIBORG pur argent et c'est du bonheur. J'ai enfin trouvé mon câble de référence.
2eme acvat
Je l' avais acheté une première avec des Neotech comme fiche xlr... Bien mais sans plus.
Monté avec des Neutrik plaqué argent, ce câble est bien meilleur. Belle scène,cohérente et très bel équilibre, dynamique et détail. Un excellent chois pour un prix très correct.
Rodage imperatif
Excellent câble de modulation. Monté en xlr avec des neotech 06612, il se montre très charnu et délivré de beaux détails sur tout le spectre. Mérite des connecteurs de bonne qualité, ce qui m'a obligé a revoir cela, non pas que les neotech 06613 soient mauvais, mais peut être pas a la hauteur de ce câble.
Pendant son " rodage" ,il peut se montrer décevant mais en mûrissant, il est vraiment très bon.
 (3)
The Ramm Audio Elite8 is designed to provide the best possible analog connection to preserve the integrity of the transmitted signal. The result is...
