Top class connectors.
Minimum resistance. Maximum quality.
ViaBlue T6s RCA connectors are made of phosphor bronze and 24 carat gold plated with an aluminum body.
The ends of the T6s connectors are removable which allows them to be interchanged between different models.
This also allows only the tip to be replaced if damaged.
The ends of the cables are to be soldered on the end fittings.
All bodies for ViaBlue™ T6s series connectors are identical except for the XLR sockets.
Only the contact parts change.
This reference only includes the end caps and not the body of the plug.
Technical Characteristics
| Specifications | |
| Product type | Banana tips |
| Contact material | Copper alloy |
| Plating | Gold plated 24k" |
| Assembly | To screw |
| Cables connection | To weld |
| Max cable diameter (mm) | N/A |
| Mounting type | To screw |
| Connectic | Male |
| Connector | Banana |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Gold |
