The 1Mii B06Pro is a Bluetooth receiver designed to add wireless reception to a Hi-Fi system or a powered speaker lacking this function. Its Bluetooth 5.3 chip supports the aptX HD and aptX Low Latency codecs, while its two antennas and Class 1 Bluetooth compatibility provide a stated range of 60m in open field and 20 to 30m indoors, depending on obstacles and interference.
Its 3.5mm jack, optical and coaxial outputs make it easy to connect to various audio systems; the device then receives music from a smartphone or tablet, but does not transmit sound to a Bluetooth headphone or television. The integrated controls allow you to adjust the volume and skip to the previous or next track, while an activatable 3D audio mode complements the listening options. The B06Pro can also be paired with an Echo device for voice control, while remaining connected to the audio system by cable.
Technical features
| Specifications | |
| Product type | Bluetooth receiver |
| Inputs | Bluetooth |
| Outputs | 1x Optical Toslink 1x Coaxial 1x Jack 3.5mm |
| Supported Bluetooth codecs | aptX Low Latency aptX HD |
| Bluetooth version | 5.3 |
| General | |
| Supply voltage | 5V DC |
| Color | Black |
| Package | 1x 1Mii B06PRO 1x USB-A to DC Jack power cable 1x Jack 3.5mm to Jack 3.5mm cable 1x Jack 3.5mm to stereo RCA cable 1x Optical Toslink to Optical Toslink cable |
| Input | Bluetooth |
| Output | Coaxial SPDIF |
| Output | Jack 3.5mm |
| Output | Optical Toslink |
| DAC / ADC Chip | NC |
| Color | Black |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | aptX HD |
| Supported Bluetooth codecs | aptX LL |
