M23 PRO Bluetooth Receiver / Transmitter
The M23 PRO is a Bluetooth 6.0 receiver/transmitter designed to provide two-way audio transmission within a hi-fi system. It utilises a dedicated dual-chip architecture – one chip for reception and the other for transmission – to manage incoming and outgoing audio streams simultaneously, whilst its OLED display allows playback information to be viewed directly.
Reference : 21661
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 27-11-2026.
M23 PRO Bluetooth 6.0 Receiver / Transmitter aptX HD / Adaptive / Low Latency
M23 PRO : Front view
The M23 PRO is a Bluetooth 6.0 receiver/transmitter designed to provide two-way audio transmission within a hi-fi system. It utilises a dedicated dual-chip architecture – one chip for reception and the other for transmission – to manage incoming and outgoing audio streams simultaneously, whilst its OLED display allows pairing information to be viewed directly.
It features a range of connections, including optical and coaxial inputs and outputs, as well as a USB host port. The device is powered by a 1200mAh battery offering up to 42 hours of transmission time and 38 hours of reception time, allowing for extended use, particularly as the automatic reconnection after pairing makes it easy to resume use on a daily basis.
Product typeBluetooth receiver / transmitter
Inputs1x Coaxial
1x Optical
1x USB-A Host
Bluetooth
Outputs1x Coaxial
1x Optical
Bluetooth
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, aptX Adaptive, aptX Low Latency
Transmission range30m
Battery1200mAh
AutonomyTransmitter: 42h
Receiver: 38h
Charging time1.5h
Supported USB formatsFAT12, FAT16, FAT32, exFAT
Supported audio formatsMP3, WAV, WMA, FLAC, APE, M4A, ALAC, AMR
Power supply5V - 2.1A
Dimensions92 x 122 x 71mm
Package1x M23 PRO
2x Antenna
1x RCA to 3.5mm jack cable
1x USB-A to USB-C cable
1x 3.5mm jack to 3.5mm jack cable
1x Optical Toslink cable
Où est la doc ???
Réception impeccable, câble fournis. Mais ou est la notice ? et même pas un site où se connecter pour une notice en ligne. Dommage, quand même....
This review has been posted for M23 PRO Bluetooth 6.0 Receiver / Transmitter aptX HD / Adaptive / Low Latency
The M23 PRO is a Bluetooth 6.0 receiver/transmitter designed to provide two-way audio transmission within a hi-fi system. It utilises a dedicated...
