The Ugreen BT505 is a Bluetooth 6.0 receiver designed for wireless audio playback from mobile devices, featuring LDAC compatibility to transmit high-resolution audio. This extends the frequency response from 20Hz to 40kHz, covering the entire audible spectrum and beyond under suitable conditions. The unit is powered by a 300mAh battery offering up to 15 hours of battery life.
| Specifications | |
| Product type | Bluetooth receiver |
| Bluetooth version | 6.0 |
| Input | Bluetooth |
| Output | 1x Stereo RCA 1x Jack 3.5mm |
| Supported Bluetooth codecs | SBC, AAC, LDAC |
| Transmission range | 10m |
| Battery | 300mAh |
| Autonomy | 15h |
| General | |
| Power supply | 5V |
| Dimensions | 71 x 66.5 x 24mm |
| Color | Black |
| Package | 1x Ugreen BT505 1x USB-A to USB-C cable 1x 3.5mm jack cable |
| Input | Bluetooth |
| Output | RCA |
| Output | Jack 3.5mm |
| DAC / ADC Chip | NC |
| Color | Black |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | AAC |
| Supported Bluetooth codecs | SBC |
| Supported Bluetooth codecs | LDAC |
