AYINO MR265PRO Bluetooth 5.0 Receiver / Transmitter
The Ayino MR265PRO is a Bluetooth 5.0 transceiver designed to enable two-way audio transmission between wired sources and wireless devices, utilising a Qualcomm CSR8675 chip to support SBC, AAC and aptX codecs in both their HD and Low Latency variants.
Reference : 21666
47,91 €tax incl.
39,92 € tax excl.
Ayino MR265PRO Bluetooth 5.0 receiver / transmitter aptX HD / Low Latency
MR265PRO : Front view
The Ayino MR265PRO is a Bluetooth 5.0 receiver / transmitter designed to enable two-way audio transmission between wired sources and wireless devices, utilising a Qualcomm CSR8675 chip to support SBC, AAC and aptX codecs in both their HD and Low Latency variants.
This versatility is further enhanced by identical input and output connections - a 3.5 mm jack, coaxial and Toslink optical - allowing the MR265PRO to be used with both analogue sources and at the heart of a digital audio system. The unit has a built-in power battery offering up to 15 hours of battery life.
Product typeBluetooth receiver / transmitter
Inputs1x Coaxial
1x Optical
1x Jack 3.5mm
Bluetooth
Outputs1x Coaxial
1x Optical
1x Jack 3.5mm
Bluetooth
Bluetooth chipQualcomm CSR8675
Supported Bluetooth codecsA2DP, AVRCP, SBC, AAC, aptX, aptX HD, aptX Low Latency
Transmission range30m
Battery400mAh
Autonomy15h
Charging time1.5h ~ 2h
Power supply voltage5V
Dimensions120 × 75 × 27mm
Weight109g
Package1x Ayino MR265PRO
1x Coaxial cable
1x Optical Toslink cable
1x 3.5mm jack cable
1x USB-A to USB-C cable
1x Mains adapter
AYINO MR265 Bluetooth 5.0 Receiver / Transmitter aptX HD / Low Latency
The Ayino MR265PRO is a Bluetooth 5.0 transceiver designed to enable two-way audio transmission between wired sources and wireless devices,...
