Jantzen Audio's C-Coil toroidal coils feature very low resistance and excellent heat resistance. This means they can withstand high power levels without overheating or causing distortion. The model in question tolerates up to 1500W (RMS) / 8Ω . In fact, they are particularly effective for bass induction when filtering your passive hi-fi speakers.
Please note that due to the electromagnetic field inherent in their construction, C-Coils are not suitable for crossovers above 1.20kHz. Likewise, they are not intended for amplification or any other active system.
Each coil is individually tested with the CLIO @ AC 1V 1kHz measurement system.
| Specifications | |
| Product type | Toroidal coil |
| Material | ETP Copper C11000, IACS certified |
| Core | Epoxy-laminated steel plates |
| Inductance | 0.82mH ±5% |
| Power handling (RMS) | 1500W / 8Ω |
| RDC | 0.05Ω ±10% |
| Wire diameter | Ø1.6mm |
| Section | 2.081mm² (14AWG) |
| General | |
| Outer diameter | Ø82mm |
| Inner diameter | Ø34mm |
| Height | Ø26mm ±3mm |
| Weight | 510g |
