Petite remarque cependant, les fiches bananes sont plutôt dures à insérer que se soit dans l'ampli ou dans les enceintes, il faut pas mal forcer : attention de rester bien droit lors de l'opération !
This speaker cable is assembled by us in the Audiophonics workshops. The choice of materials has been carefully considered and every detail and finish has been checked to offer you a high-quality cable that remains affordable. It is composed of a Mogami 3103 cable with OFC copper conductors and gold-plated Viborg banana plugs.
This speaker cable has been developed for music lovers seeking optimal quality without loss and great neutrality across the entire bandwidth for superior musicality above all else.
The Mogami 3103 is a high-quality speaker cable designed to allow your audio devices and speakers to deliver their full potential. Each conductor, with a cross-section of 4mm² (11AWG), is made from Mogami Neglex OFC copper in a configuration designed to offer transparency and sound precision.
These Viborg banana plugs feature high-quality design. The contacts are made of a gold-plated copper alloy, ensuring good conductivity and durability. The body is made of aluminum for greater durability.
| Specifications | |
| Product type | HP cable |
| Connectors | Viborg banana plugs |
| Length | 1.5m |
| MOGAMI 3103 Specifications | |
| Conductors number | 2 |
| Conductors material | OFC copper |
| Conductors section | 4mm² (12AWG) |
| Conductors insulation diameter | Ø4.5mm |
| Insulation material | PVC |
| External diameter | Ø12mm |
| External sheath material | PVC flexible |
| Weight / 100m | 20kg |
| DC resistance | 0.005Ω/m |
| Inductance @ 20°C 1kHz | 0.6µH/m |
| Capacitance @ 20°C | 100Hz: 106pF/m 1kHz: 93pF/m 10kHz: 83pF/m 50kHz: 76pF/m 100kHz: 74pF/m |
| Max. voltage | 500V DC (15s) |
| Working temperature min / max | -20°C / +70°C |
| Specification of Viborg banana plugs | |
| Contact material | Copper alloy |
| Contact plating | Gold |
| Body material | Aluminium |
| Maximum cable diameter | Ø8.5mm |
| Max conductor diameter | Ø4.5mm |
| Mounting type | To screw |
| Dimensions | 41.5 x 8.5mm |
| General | |
| Package | Sold by pair |
| Length (m) | 1.5 |
| Shielding | No |
| Section (mm²) | 4.00 |
| Connector | Banana |
| Conductors Plating (Cable) | None |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Olivier F.
Olivier F.
