LUDIC ORPHEUS Speaker Cable 2m (Pair)
The Ludic Orpheus speaker cable is designed to transmit the audio signal between the amplifier and the speakers with low resistance and excellent electrical stability. It features an OCC copper design combined with double shielding, which helps to minimise interference whilst maintaining signal integrity. Intended for use in home hi-fi systems, it combines conductivity, protection and connection flexibility to ensure a reliable link between the various components of the audio system.
By buying this product you get 27 loyalty points
Reference : 21615
279,00 €tax incl.
232,50 € tax excl.
Shipping date: 26-11-2026.
Ludic Orpheus Speaker Cable Banana / Spades OCC Copper 2x2.289mm² 2m (Pair)
Ludic Orpheus : Front view
Ludic Orpheus: OCC copper cable
The Ludic Orpheus features two OCC copper conductors with a cross-section of 2.289mm², ensuring low resistance whilst providing stable signal transmission along the entire length of the cable. The signal is protected by double shielding combining an aluminium foil layer with a tinned copper braid, effectively reducing EMI/RFI interference whilst maintaining good installation flexibility. The assembly is finished with an attractive braided cotton sheath, bringing the total cable diameter to 8mm.
Ludic Orpheus : View of the separator
Ludic Orpheus : Banana plugs and spades
Ludic Orpheus: Modular connectors
The connectors feature 24-carat gold-plated copper contacts, ensuring stable conductivity whilst minimising oxidation and corrosion over time. Their nickel-plated brass bodies enhance their mechanical strength, whilst the interchangeable terminals, banana plugs and screw-on spades, allow the cable to be adapted to different types of terminal blocks whilst maintaining a secure and long-lasting connection.
Product typeSpeaker cable
ConnectorsInterchangeable banana plugs
Interchangeable spades
Length2m
Number of conductors2
Conductive materialOCC Copper
Conductors section2.289mm²
Outer diameter8mm ±0.5mm
Outer sheath materialCotton
Contact materialCopper
Contact plating24-carat gold
Housing materialNickel-plated brass
Package1x Pair of Ludic Orpheus cables
8x Banana plugs
8x Spades
Length (m)2.0
ShieldingYes
Section (mm²)0.22
ConnectorBanana
ConnectorSpade
LUDIC ORPHEUS Speaker Cable Banana / Spades OCC Copper 2x2.29mm² 2m (Pair)
The Ludic Orpheus speaker cable is designed to transmit the audio signal between the amplifier and the speakers with low resistance and excellent...
