TRIANGLE RED Speaker Cables 5m (Pair)
This Red speaker cable from Triangle is made of 99.9% pure OFC copper for optimal signal conductivity and faithful sound reproduction. It is designed to connect Hi-Fi speakers to an audio amplifier.
Reference : 21792
249,00 €tax incl.
207,50 € tax excl.
Triangle Red Speaker Cables OFC Copper 2.5mm² 5m (Pair)
Photo of the speaker cable
This Red speaker cable from Triangle is made of 99.9% pure OFC copper for optimal signal conductivity and faithful sound reproduction with high precision. It is designed to connect passive speakers to an audio amplifier. To this end, the cable comes pre-fitted with 3.6mm gold-plated BP450 banana plugs featuring a spring-loaded tab that ensures a secure fit in the terminals.
To ensure the conductor is protected, it is insulated with multiple layers combining PVC and cotton sheets, while the outer insulation consists of a PVC core and a braided textile sheath, ensuring signal integrity and stability. The connectors are marked with arrows to facilitate installation.
Product typeSpeaker cable
Length5m
ConnectorsBP450 Banana Plugs
Conductive material99.99% pure OFC copper
Connector platingGold
Banana plug diameter3.6mm
ShieldingYes
Section2x2.5mm²
SheathBraided
ColorBlack and red
Weight1.21kg
PackageSold in pairs
Length (m)5.0
ShieldingYes
Section (mm²)2.5
ConnectorBanana
TRIANGLE RED Speaker Cables OFC Copper 2.5mm² 5m (Pair)
This Red speaker cable from Triangle is made of 99.9% pure OFC copper for optimal signal conductivity and faithful sound reproduction. It is...
