VIABLUE NF-S1 T8 Interconnect Cable Jack 3.5mm 1m Black
The VIABLUE NF-S1 T8 is a high-end 3.5mm stereo jack interconnect cable designed to transmit audio signals with maximum fidelity.
Reference : 22333
179,91 €tax incl.
149,92 € tax excl.
VIABLUE NF-S1 T8 3.5mm Interconnect Cable Jack 3.5mm Stereo Male Shielded OFC Copper 1m Black
VIABLUE NF-S1 T8
The VIABLUE NF-S1 T8 is a high-end 3.5mm stereo jack interconnect cable designed to transmit audio signals with maximum fidelity. Intended for connecting devices equipped with a 3.5mm jack interface, it uses two internal tinned OFC copper conductors, each consisting of 19 strands of 0.19mm, combined with polyethylene insulation ensuring excellent electrical stability. Its sophisticated “Quattro Silver” shielding combines four distinct layers, including two silver-plated helical shields and two ALU-PET foil shields, providing particularly efficient signal transmission and excellent protection against electromagnetic interference.
The NF-S1 T8 is fitted with VIABLUE T8 3.5mm stereo jack connectors featuring 24-carat gold plating for optimal contact pressure and excellent resistance to oxidation. It also benefits from a VIABLUE Ferrite Filter 9 for interference-free transmission and a Cobra protective sleeve ensuring both durability and elegance.
With an external diameter of 18mm, a 21AWG conductor cross-section, a capacitance of 50pF/m for the conductors and 100pF/m for the shielding, this cable guarantees transparent sound reproduction, precise bass response, and exceptionally detailed high frequencies.
Overview of the VIABLUE NF-S1 T8 Cable
1Outer Jacket
2Insulation
3Tinned OFC Copper Spiral Shield
4Silver ALU-PET Foil Shield
5Tinned OFC Copper Spiral Shield
6Silver ALU-PET Foil Shield
7Silver-Plated OFC Copper Conductor
8Soft Filler
Technical Specifications
Product TypeInterconnect cable
Connectors2x 3.5mm Stereo Male Jack
Cable Structure19 individual strands of 0.19mm
Conductor MaterialPure Copper
ShieldingQuattro
Cable DiameterØ18mm
Cross-Section0.410mm² (21AWG)
InsulationPVC
T8 Connector Contact Plating24K Gold
Anti-Interference FilterViablue Ferrite Filter 9
Length1m
Package Contents1x VIABLUE NF-S1 T8 3.5mm Stereo Jack Interconnect Cable
Length (m)1.0
ShieldingYes
Section (mm²)0.410
ConnectorJack 3.5mm
VIABLUE NF-S1 T8 Interconnect Cable Jack 3.5mm Stereo Male Shielded OFC Copper 1m Black
